Commit 1e37ad16 authored by Laurent Belcour's avatar Laurent Belcour Committed by Laurent Belcour
[Bug] Remove character 'd' from floating point value
parent 1af38761
...@@ -115,7 +115,7 @@ static void read_confidence_interval(std::istream& input, ...@@ -115,7 +115,7 @@ static void read_confidence_interval(std::istream& input,
else else
// Confidence interval data not provided in INPUT. // Confidence interval data not provided in INPUT.
double dt = args.get_double("dt", 0.1d); double dt = args.get_double("dt", 0.1);
min_dt = -dt; min_dt = -dt;
max_dt = dt; max_dt = dt;
