Commit 1bceb8f6 authored by Ludovic Courtès's avatar Ludovic Courtès
core: vertical_segment: Consolidate 'Eigen::Map' creation as methods.
parent 40f0c97f
...@@ -130,13 +130,7 @@ void vertical_segment::get(int i, vec& yl, vec& yu) const ...@@ -130,13 +130,7 @@ void vertical_segment::get(int i, vec& yl, vec& yu) const
vec vertical_segment::get(int i) const vec vertical_segment::get(int i) const
// Omit the confidence interval data. return data_view().col(i);
auto relevant_rows = _parameters.dimX() + _parameters.dimY();
auto matrix =
Map<MatrixXd, 0, OuterStride<> >(_data.get(), relevant_rows, size(),
OuterStride<>(column_number()));
return matrix.col(i);
void vertical_segment::set(int i, const vec& x) void vertical_segment::set(int i, const vec& x)
...@@ -146,8 +140,7 @@ void vertical_segment::set(int i, const vec& x) ...@@ -146,8 +140,7 @@ void vertical_segment::set(int i, const vec& x)
if(x.size() == column_number() if(x.size() == column_number()
|| x.size() == _parameters.dimX() + _parameters.dimY()) || x.size() == _parameters.dimX() + _parameters.dimY())
auto matrix = matrix_view(); auto row = matrix_view().row(i);
auto row = matrix.row(i);
row.head(x.size()) = x; row.head(x.size()) = x;
} else { } else {
std::cerr << "<<ERROR>> Passing an incorrect element to vertical_segment::set" << std::endl; std::cerr << "<<ERROR>> Passing an incorrect element to vertical_segment::set" << std::endl;
...@@ -113,13 +113,24 @@ class vertical_segment : public data ...@@ -113,13 +113,24 @@ class vertical_segment : public data
return _parameters.dimX() + 3 * _parameters.dimY(); return _parameters.dimX() + 3 * _parameters.dimY();
// Return a matrix view of this data. // Return a matrix view of the data: all the Xi and Yi followed by
// confidence interval data (lower and upper bound of the Yi). Thus,
// it has (dimX + 3 * dimY) columns and SIZE rows.
Eigen::Map<Eigen::MatrixXd> matrix_view() const Eigen::Map<Eigen::MatrixXd> matrix_view() const
return Eigen::Map<Eigen::MatrixXd>(_data.get(), size(), return Eigen::Map<Eigen::MatrixXd>(_data.get(), size(),
column_number()); column_number());
// Return a matrix view of DATA that excludes confidence interval data.
// It has (dimX + dimY) columns and SIZE rows.
Eigen::Map<Eigen::MatrixXd, 0, Eigen::OuterStride<> > data_view() const
return Eigen::Map<Eigen::MatrixXd, 0, Eigen::OuterStride<> >
(_data.get(), _parameters.dimX() + _parameters.dimY(), size(),
Eigen::OuterStride<>(column_number()));
protected: // method protected: // method
//! \brief From a correct input configuration 'x' with size //! \brief From a correct input configuration 'x' with size
