Commit ee79dbf4 authored by Laurent Belcour's avatar Laurent Belcour
Refactoring the core lib and the plugin manager to provide
static access to function data and fitter objects. It will
be used later in the parallel fitter plugin to evaluate the
resulting function per thread.
parent c89559f9
...@@ -5,6 +5,7 @@ ...@@ -5,6 +5,7 @@
#include <QCoreApplication> #include <QCoreApplication>
#include <QPluginLoader> #include <QPluginLoader>
#include <QtPlugin> #include <QtPlugin>
#include <QLibrary>
#include <QDir> #include <QDir>
// Create the object, parse the argument and load // Create the object, parse the argument and load
...@@ -78,12 +79,22 @@ plugins_manager::plugins_manager(const arguments& args) ...@@ -78,12 +79,22 @@ plugins_manager::plugins_manager(const arguments& args)
#define USING_STATIC
#ifdef USING_STATIC
typedef function* (*FunctionPrototype)();
typedef fitter* (*FitterPrototype)();
typedef data* (*DataPrototype)();
#endif
// Get instances of the function, the data and the // Get instances of the function, the data and the
// fitter // fitter
function* plugins_manager::get_function() const function* plugins_manager::get_function()
if(_functions.empty()) #ifdef USING_STATIC
return new rational_function() ;
#else
return new rational_function() ; return new rational_function() ;
...@@ -91,17 +102,23 @@ function* plugins_manager::get_function() const ...@@ -91,17 +102,23 @@ function* plugins_manager::get_function() const
return _functions.begin()->second ; return _functions.begin()->second ;
#endif
data* plugins_manager::get_data() const data* plugins_manager::get_data() const
//if(_datas.empty()) //if(_datas.empty())
std::cout << "<<DEBUG>> using vertical segment data loader" << std::endl ; #ifdef DEBUG
#endif
return new vertical_segment() ; return new vertical_segment() ;
else else
#ifdef DEBUG
std::cout << "<<DEBUG>> using \"" << _datas.begin()->first << "\" data loader" << std::endl ; std::cout << "<<DEBUG>> using \"" << _datas.begin()->first << "\" data loader" << std::endl ;
#endif
return _datas.begin()->second ; return _datas.begin()->second ;
...@@ -113,17 +130,37 @@ fitter* plugins_manager::get_fitter() const ...@@ -113,17 +130,37 @@ fitter* plugins_manager::get_fitter() const
else else
#ifdef DEBUG
std::cout << "<<DEBUG>> using \"" << _fitters.begin()->first << "\"" << std::endl ; std::cout << "<<DEBUG>> using \"" << _fitters.begin()->first << "\"" << std::endl ;
#endif
return _fitters.begin()->second ; return _fitters.begin()->second ;
// fitter, select one based on the name. Return null // fitter, select one based on the name. Return null
// if no one exist. // if no one exist.
function* plugins_manager::get_function(const std::string& n) const function* plugins_manager::get_function(const std::string& n)
#ifdef USING_STATIC
FunctionPrototype myFunction = (FunctionPrototype) QLibrary::resolve(QString(n.c_str()), "_Z16provide_functionv");
if(myFunction != NULL)
#ifdef DEBUG
std::cout << "<<DEBUG>> using function provider in file \"" << n << "\"" << std::endl;
#endif
return myFunction();
else
std::cerr << "<<ERROR>> no function provider found in file \"" << n << "\"" << std::endl;
#else
if(_functions.count(n) == 0) if(_functions.count(n) == 0)
...@@ -132,17 +169,22 @@ function* plugins_manager::get_function(const std::string& n) const ...@@ -132,17 +169,22 @@ function* plugins_manager::get_function(const std::string& n) const
return _functions.find(n)->second ; return _functions.find(n)->second ;
#endif
data* plugins_manager::get_data(const std::string& n) const data* plugins_manager::get_data(const std::string& n) const
if(_datas.count(n) == 0) if(_datas.count(n) == 0)
#ifdef DEBUG
std::cout << "<<DEBUG>> using vertical segment data loader" << std::endl ; std::cout << "<<DEBUG>> using vertical segment data loader" << std::endl ;
#endif
else else
#ifdef DEBUG
std::cout << "<<DEBUG>> using \"" << n << "\" data loader" << std::endl ; std::cout << "<<DEBUG>> using \"" << n << "\" data loader" << std::endl ;
#endif
return _datas.find(n)->second ; return _datas.find(n)->second ;
...@@ -154,7 +196,9 @@ fitter* plugins_manager::get_fitter(const std::string& n) const ...@@ -154,7 +196,9 @@ fitter* plugins_manager::get_fitter(const std::string& n) const
else else
#ifdef DEBUG
std::cout << "<<DEBUG>> using \"" << n << "\"" << std::endl ; std::cout << "<<DEBUG>> using \"" << n << "\"" << std::endl ;
#endif
return _fitters.find(n)->second ; return _fitters.find(n)->second ;
...@@ -25,13 +25,13 @@ class plugins_manager ...@@ -25,13 +25,13 @@ class plugins_manager
//! \brief Get instances of the function, the data and the fitter. Select //! \brief Get instances of the function, the data and the fitter. Select
//! the first in the map, //! the first in the map,
function* get_function() const ; static function* get_function() ;
data* get_data() const ; data* get_data() const ;
fitter* get_fitter() const ; fitter* get_fitter() const ;
//! \brief Get instances of the function, the data and the fitter, select one //! \brief Get instances of the function, the data and the fitter, select one
//! based on the name. Return null if no one exist. //! based on the name. Return null if no one exist.
function* get_function(const std::string& n) const ; static function* get_function(const std::string& n) ;
data* get_data(const std::string& n) const ; data* get_data(const std::string& n) const ;
fitter* get_fitter(const std::string& n) const ; fitter* get_fitter(const std::string& n) const ;
...@@ -8,6 +8,7 @@ ...@@ -8,6 +8,7 @@
#include <algorithm> #include <algorithm>
#include <cmath> #include <cmath>
rational_function::rational_function() : a(), b() rational_function::rational_function() : a(), b()
...@@ -85,7 +85,8 @@ bool rational_fitter_parallel::fit_data(const data* dat, function* fit) ...@@ -85,7 +85,8 @@ bool rational_fitter_parallel::fit_data(const data* dat, function* fit)
double min_delta = std::numeric_limits<double>::max(); double min_delta = std::numeric_limits<double>::max();
int nb_sol_found = 0; int nb_sol_found = 0;
int np, nq ; int np, nq ;
#pragma omp parallel for
for(int j=1; j<i; ++j) for(int j=1; j<i; ++j)
int temp_np = i - j; int temp_np = i - j;
...@@ -97,7 +98,7 @@ bool rational_fitter_parallel::fit_data(const data* dat, function* fit) ...@@ -97,7 +98,7 @@ bool rational_fitter_parallel::fit_data(const data* dat, function* fit)
bool is_fitted = fit_data(d, temp_np, temp_nq, r, p, q, delta); bool is_fitted = fit_data(d, temp_np, temp_nq, r, p, q, delta);
if(is_fitted) if(is_fitted)
#pragma omp critical #pragma omp critical
++nb_sol_found ; ++nb_sol_found ;
if(delta < min_delta) if(delta < min_delta)
...@@ -164,7 +165,7 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* d, int np, int n ...@@ -164,7 +165,7 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* d, int np, int n
// the function return a ration BRDF function and a boolean // the function return a ration BRDF function and a boolean
bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int nq, int ny, bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int nq, int ny,
rational_function* rf, rational_function* rf,
vec& p, vec& q, double& delta) vec& p, vec& q, double& delta)
rational_function* r = dynamic_cast<rational_function*>(rf) ; rational_function* r = dynamic_cast<rational_function*>(rf) ;
const vertical_segment* d = dynamic_cast<const vertical_segment*>(dat) ; const vertical_segment* d = dynamic_cast<const vertical_segment*>(dat) ;
...@@ -175,25 +176,25 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int ...@@ -175,25 +176,25 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int
const int m = d->size(); // 2*m = number of constraints const int m = d->size(); // 2*m = number of constraints
const int n = np+nq; // n = np+nq const int n = np+nq; // n = np+nq
quadratic_program qp(np, nq); quadratic_program qp(np, nq);
#ifndef TODO_PUT_IN_METHOD #ifndef TODO_PUT_IN_METHOD
for(int i=0; i<d->size()/2; ++i) for(int i=0; i<d->size()/10; ++i)
// Create two vector of constraints // Create two vector of constraints
vec c1(n), c2(n); vec c1(n), c2(n);
get_constraint(2*i, np, nq, ny, d, r, c1, c2); get_constraint(10*i, np, nq, ny, d, r, c1, c2);
qp.add_constraints(c1); qp.add_constraints(c1);
qp.add_constraints(c2); qp.add_constraints(c2);
#endif #endif
// do do
QuadProgPP::Vector<double> x(n); QuadProgPP::Vector<double> x(n);
...@@ -206,11 +207,26 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int ...@@ -206,11 +207,26 @@ bool rational_fitter_parallel::fit_data(const vertical_segment* dat, int np, int
#endif #endif
return true; return true;
int current = 0, i=0;
while(i < 100 && current < m)
int next = quadratic_program::next_unmatching_constraint(current, ny, );
vec c1(n), c2(n);
get_constraint(next, np, nq, ny, d, r, c1, c2);
// int current = 0; ++i;
// int next = quadratic_program::next_unmatching_constraint(current, ny, ); current = next;
// while(qp.nb_constraints() < 2*m); while(qp.nb_constraints() < 2*m);
return false; return false;
...@@ -7,6 +7,11 @@ ...@@ -7,6 +7,11 @@
function* provide_function()
return new rational_function_chebychev();
rational_function_chebychev::rational_function_chebychev() : rational_function() rational_function_chebychev::rational_function_chebychev() : rational_function()
