GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
alta
alta
e9791b19
e9791b19
Laurent Belcour
Debugging the brdf2data and brdf2gnuplot programs
3bd27e30
2
2 changed files
57 additions
64 deletions
+57
-64
sources/softs/brdf2data/main.cpp
+3
-9
sources/softs/brdf2gnuplot/main.cpp
+54
-55
e9791b19
@@ -58,8 +58,7 @@ int main(int argc, char** argv)
// Get the associated data object and load the file is any
ptr
d
NULL
ptr
d
plugins_manager
get_data
args
"data"
d
plugins_manager
get_data
args
"data"
if
args
is_defined
"data-file"
if
args
is_defined
"data-file"
d
load
args
"data-file"
d
load
args
"data-file"
@@ -67,14 +66,9 @@ int main(int argc, char** argv)
// Get the output object. In the case where it is not a VS file, we use
// the load object.
// the load object.
ptr
d_out
NULL
ptr
d_out
plugins_manager
get_data
args
"data"
if
dynamic_pointer_cast
vertical_segment
d
if
vertical_segment
d
d_out
d
else
d_out
ptr
new
vertical_segment
d_out
setDimX
d
dimX
d_out
setDimX
d
dimX
d_out
setDimY
d
dimY
d_out
setDimY
d
dimY
d_out
setParametrization
d
input_parametrization
d_out
setParametrization
d
e9791b19
@@ -67,13 +67,19 @@ int main(int argc, char** argv)
// Load a data file
// Load a data file
ptr
d
NULL
if
args
is_defined
"data"
args
is_defined
"in-data"
if
args
is_defined
"data"
args
is_defined
"in-data"
d
plugins_manager
get_data
args
"data"
ptr
d
plugins_manager
get_data
args
"data"
if
vertical_segment
d
// Load data file if the plugin manager created a plugin object.
if
d
d
load
args
"data-file"
else
d
load
args
"in-data"
std
cerr
"<<ERROR>> unable to load the data plugin"
std
endl
return
// Print the distance to the data to check if it correspond to the value
@@ -97,67 +103,60 @@ int main(int argc, char** argv)
linear_plot
true
linear_plot
true
if
d
for
int
i
i
d
size
i
for
int
i
i
d
size
i
vec
v
d
get
i
vec
x
f
dimX
// Convert the data to the function's input space.
if
f
params
UNKNOWN_INPUT
vec
v
d
get
i
memcpy
x
v
f
dimX
sizeof
double
vec
x
f
dimX
else
if
f
params
UNKNOWN_INPUT
params
convert
v
d
f
x
memcpy
x
v
f
dimX
sizeof
double
// Evaluate the function. I can add the cosine term to the BRDF
else
// value.
double
costerm
1.0
params
convert
v
d
f
x
if
cos_plot
double
cart
6
params
convert
x
f
params
CARTESIAN
cart
// value.
costerm
cart
5
cart
2
double
costerm
1.0
if
cos_plot
vec
y2
costerm
f
value
x
double
cart
6
params
convert
x
f
params
CARTESIAN
cart
costerm
cart
5
cart
2
vec
y2
costerm
f
value
x
if
linear_plot
if
linear_plot
for
int
u
u
d
dimX
u
file
v
u
\t
else
file
i
\t
for
int
u
u
d
dimY
u
if
plot_error
for
int
u
u
d
dimX
u
file
v
d
dimX
u
y2
u
\t
file
v
u
\t
else
else
if
linear_plot
file
i
\t
file
v
d
dimX
u
y2
u
v
d
dimX
u
\t
else
for
int
u
u
d
dimY
u
if
plot_error
file
y2
u
\t
file
v
d
dimX
u
y2
u
\t
else
if
linear_plot
file
v
d
dimX
u
y2
u
v
d
dimX
u
\t
else
file
y2
u
\t
file
std
endl
else
file
std
endl
std
cerr
"<<ERROR>> data argument is incorrectly defined"
std
endl
else
if
args
is_defined
"polar-plot"
else
if
args
is_defined
"polar-plot"
