GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
e5055494
e5055494
Laurent Belcour
Updating the rational loader
343a1652
2
2 changed files
6 additions
5 deletions
+6
-5
sources/core/plugins_manager.cpp
+3
-3
sources/core/rational_function.cpp
+3
-2
e5055494
@@ -94,16 +94,16 @@ function* plugins_manager::get_function() const
plugins_manager
get_data
const
if
_datas
empty
if(_datas.empty())
std
cout
"<<DEBUG>> using vertical segment data loader"
std
endl
return
new
vertical_segment
else
std::cout << "<<DEBUG>> using \"" << _datas.begin()->first << "\" data loader" << std::endl ;
return _datas.begin()->second ;
fitter
plugins_manager
get_fitter
const
e5055494
@@ -252,7 +252,7 @@ void rational_function::load(const std::string& filename)
continue
else
else
if
j
nY
int
index
double
val
@@ -281,13 +281,14 @@ void rational_function::load(const std::string& filename)
for(int i=0; i<a.size(); ++i) {
std::cout << a[i] << "\t" ;
for(int i=0; i<b.size(); ++i) {
std::cout << b[i] << "\t" ;
void
rational_function
save
const
std
string
filename
const
arguments
args
const
