Commit dee59a35 authored by Laurent Belcour's avatar Laurent Belcour
Adding the possiblity to use a Cholesky decomposition of the normal equation
during the computation of the Hessian.
parent e4a343b1
......@@ -132,7 +132,16 @@ bool nonlinear_fitter_ceres::fit_data(const data* d, function* fit, const argume
options.max_num_iterations = args.get_int("ceres-max-num-iterations", 50); // Default value = 50
options.linear_solver_type = ceres::DENSE_QR;
if(args["ceres-factorization"] == "normal-cholesky")
options.linear_solver_type = ceres::DENSE_NORMAL_CHOLESKY;
else
if(args.is_defined("ceres-debug"))
options.minimizer_progress_to_stdout = true; // Default value = false;
......@@ -45,6 +45,8 @@
* <ul>
* <li><b>--ceres-max-num-iterations</b> <em>[int]</em> to control the number
* of iterations the non linear solver will take before returning a solution</li>
* <li><b>--ceres-factorizer</b> <em>[string]</em> to control the type of dense
* factorization method used to solve the <a href="http://homes.cs.washington.edu/~sagarwal/ceres-solver/stable/solving.html?highlight=dense_qr#equation-normal">normal equations</a></li>
* </ul>
class nonlinear_fitter_ceres: public fitter
