Commit cd54dd1d authored by PACANOWSKI Romain's avatar PACANOWSKI Romain
wrong implementation. code commented and replaced with false assertion
parent 2da34fe1
...@@ -6,6 +6,7 @@ ...@@ -6,6 +6,7 @@
#include <limits> #include <limits>
#include <algorithm> #include <algorithm>
#include <cmath> #include <cmath>
#include <cassert>
#include <core/common.h> #include <core/common.h>
...@@ -86,13 +87,15 @@ void smith::save_body(std::ostream& out, const arguments& args) const ...@@ -86,13 +87,15 @@ void smith::save_body(std::ostream& out, const arguments& args) const
if(is_shader) if(is_shader)
out << std::endl; // out << std::endl;
out << "vec3 shadowing_smith(vec3 L, vec3 V, vec3 N, vec3 X, vec3 Y, vec3 R)" << std::endl; // out << "vec3 shadowing_smith(vec3 L, vec3 V, vec3 N, vec3 X, vec3 Y, vec3 R)" << std::endl;
out << "{" << std::endl; // out << "{" << std::endl;
out << "\tvec3 H = normalize(L + V);" << std::endl; // out << "\tvec3 H = normalize(L + V);" << std::endl;
out << "\treturn R + (vec3(1.0) - R) * pow(1.0f - clamp(dot(H,V), 0.0f, 1.0f), 5);" << std::endl; // out << "\treturn R + (vec3(1.0) - R) * pow(1.0f - clamp(dot(H,V), 0.0f, 1.0f), 5);" << std::endl;
out << "}" << std::endl; // out << "}" << std::endl;
std::cerr << " IMPLEMENT ME AT " << __FILE__ << " " << __LINE__ << std::endl;
assert(0);
