Commit abd62711 authored by Ludovic Courtès's avatar Ludovic Courtès
core: plugins_manager: Add 'load_data' static methods.
parent 7396f610
...@@ -466,6 +466,36 @@ ptr<data> plugins_manager::get_data(const std::string& n, const arguments& args) ...@@ -466,6 +466,36 @@ ptr<data> plugins_manager::get_data(const std::string& n, const arguments& args)
return ptr<data>(new vertical_segment()) ; return ptr<data>(new vertical_segment()) ;
ptr<data> plugins_manager::load_data(const std::string& type, std::istream& input,
ptr<data> result = get_data(type, args);
if (result) result->load(input, args);
return result;
// Load data from an input file.
ptr<data> plugins_manager::load_data(const std::string& file,
std::ifstream stream;
// Raise an exception when 'open' fails, and open in binary mode to
// placate Windows.
stream.exceptions(std::ios::failbit);
stream.open(file.c_str(), std::ifstream::binary);
stream.exceptions(std::ios::goodbit);
ptr<data> result = load_data(type, stream, args);
stream.close(); // FIXME: make it auto-close
return result;
ptr<fitter> plugins_manager::get_fitter(const std::string& n) ptr<fitter> plugins_manager::get_fitter(const std::string& n)
if(n.empty()) if(n.empty())
...@@ -57,6 +57,15 @@ class plugins_manager ...@@ -57,6 +57,15 @@ class plugins_manager
//! filename n. Return null if no one exist. //! filename n. Return null if no one exist.
static ptr<data> get_data(const std::string& n, const arguments& args = arguments()); static ptr<data> get_data(const std::string& n, const arguments& args = arguments());
//! \brief Load from INPUT an instance of TYPE and return it.
static ptr<data> load_data(const std::string& type, std::istream& input,
//! \brief Load from FILE an instance of TYPE and return it.
static ptr<data> load_data(const std::string& file,
//! \brief get an instance of the fitter that is defined in the plugin with //! \brief get an instance of the fitter that is defined in the plugin with
static ptr<fitter> get_fitter(const std::string& n) ; static ptr<fitter> get_fitter(const std::string& n) ;
