Commit 9f091964 authored by Laurent Belcour's avatar Laurent Belcour
Doing rational fitting on the sparse data
parent 8af6d07f
...@@ -31,7 +31,8 @@ ...@@ -31,7 +31,8 @@
<action name="data2brdf"> <action name="data2brdf">
<!-- Input and output arguments of the action --> <!-- Input and output arguments of the action -->
<input name="/tmp/yellow_slice_inc30.dat" /> <input name="../papers/retro/mesures/original/3M_jaune/3d/633nm/Fichiers\ definitifs/densify_helmholtz/3M_jaune_3D+3DS+3DR_dense__nbsgrid_81.alta" />
<!--<input name="/tmp/yellow_slice_inc30.dat" />-->
<output name="./results/3d/retro/half/3M_jaune_rat.brdf" /> <output name="./results/3d/retro/half/3M_jaune_rat.brdf" />
<!-- Define the function to use --> <!-- Define the function to use -->
...@@ -40,7 +41,8 @@ ...@@ -40,7 +41,8 @@
<!-- Define the ftting procedure to use --> <!-- Define the ftting procedure to use -->
<!--<plugin type="fitter" name="rational_fitter_quadprog" />--> <!--<plugin type="fitter" name="rational_fitter_quadprog" />-->
<plugin type="fitter" name="rational_fitter_parallel" /> <plugin type="fitter" name="rational_fitter_parallel" />
<parameter name="min-np" value="53" /> <parameter name="min-np" value="100" />
<!--<parameter name="min-np" value="53" />-->
<parameter name="min-nq" value="10" /> <parameter name="min-nq" value="10" />
<parameter name="np" value="100" /> <parameter name="np" value="100" />
<parameter name="nq" value="100" /> <parameter name="nq" value="100" />
...@@ -56,6 +58,7 @@ ...@@ -56,6 +58,7 @@
<input name="./results/3d/retro/half/3M_jaune_rat.brdf" /> <input name="./results/3d/retro/half/3M_jaune_rat.brdf" />
<output name="./results/3d/retro/half/3M_jaune_rat.dat" /> <output name="./results/3d/retro/half/3M_jaune_rat.dat" />
<parameter name="data" value="/tmp/yellow_slice_inc30.dat" /> <parameter name="data" value="../papers/retro/mesures/original/3M_jaune/3d/633nm/Fichiers\ definitifs/densify_helmholtz/3M_jaune_3D+3DS+3DR_dense__nbsgrid_81.alta" />
<!--<parameter name="data" value="/tmp/yellow_slice_inc30.dat" />-->
</action> </action>
</alta> </alta>
