Commit 97b769af authored by Ludovic Courtès's avatar Ludovic Courtès
plugins_manager: Fix typos in debugging messages.
parent 90c13f8c
/* ALTA --- Analysis of Bidirectional Reflectance Distribution Functions /* ALTA --- Analysis of Bidirectional Reflectance Distribution Functions
Copyright (C) 2014, 2015 CNRS Copyright (C) 2014, 2015 CNRS
Copyright (C) 2013, 2014 Inria Copyright (C) 2013, 2014, 2015 Inria
This file is part of ALTA. This file is part of ALTA.
...@@ -423,7 +423,7 @@ ptr<data> plugins_manager::get_data(const std::string& n) ...@@ -423,7 +423,7 @@ ptr<data> plugins_manager::get_data(const std::string& n)
if(myData != NULL) if(myData != NULL)
#ifdef DEBUG #ifdef DEBUG
std::cout << "<<DEBUG>> using function provider in file \"" << n << "\"" << std::endl; std::cout << "<<DEBUG>> using data provider in file \"" << n << "\"" << std::endl;
#endif #endif
return myData(); return myData();
...@@ -447,7 +447,7 @@ ptr<fitter> plugins_manager::get_fitter(const std::string& n) ...@@ -447,7 +447,7 @@ ptr<fitter> plugins_manager::get_fitter(const std::string& n)
if(myFitter != NULL) if(myFitter != NULL)
std::cout << "<<DEBUG>> using function provider in file \"" << n << "\"" << std::endl; std::cout << "<<DEBUG>> using fitter provider in file \"" << n << "\"" << std::endl;
#endif #endif
return myFitter(); return myFitter();
