Commit 975297cb authored by Romain Pacanowski's avatar Romain Pacanowski
added more doxygen comments to document the usage of data2data
parent 87d45059
......@@ -15,11 +15,11 @@
* This command transform a \ref data object into another data object.
* \details
* This command is useful to change the parametrization of a data file,
* or to perform interpolation of sample values (i.e. to fill gaps).
* or to perform interpolation of sample values (i.e., to fill gaps).
* <h3>Usage</h3>
* \verbatim
data2data --input data.file --output data.file --out-data exporter.so --in-data importer.so
data2data --input data.file --output data.file --out-data output_plugin --in-data input_plugin OPTIONS
\endverbatim
* <h3>Parameters</h3>
......@@ -28,18 +28,67 @@
* loading plugin is defined using the option <b>\-\-in-data <i>
* filename</i></b>.
* </li>
* <li><b>\-\-in-data <i>filename</i></b> specify the data plugin
* <li><b>\-\-in-data <i>filename</i></b> specifies the data plugin (cf. \ref datas)
* used to load the input file. If this option is not specified, the
* loading plugin will be a \ref vertical_segment plugin. \note If
* the input plugin is not interpolating, like \ref vertical_segment,
* loading plugin will be a \ref alta::vertical_segment plugin. \note If
* the input plugin is not interpolating, like \ref alta::vertical_segment,
* you can only use the reparametrization tool.</li>
* <li><b>\-\-output <i>filename</i></b> the resulting data file.
* </li>
* <li><b>\-\-out-data <i>filename</i></b></li> specify the data plugin
* <li><b>\-\-out-data <i>filename</i></b></li> specifies the data plugin
* used to export the data. This parameter is optional. If not defined,
* the output format will be ALTA's \ref format.
* </li>
* </ul>
* <h3>Options</h3>
* <ul>
* <li>
* <b>--params <i>NAME</i> </b> specifies the name of the parametrization to be used
* no output data plugin is specified.
* Please see --help-params for the list of available parametrizations.
* </li>
* <li>
* <b>--all-values </b> exports all data regardless of their physical validity
* </li>
* <li>
* <b>--data-correct-cosine</b> divides the value of the data points by the product of
* the light and view vector dot product with the normal
* </li>
* </ul>
* <h4>Data Filtering (currently only supported with ALTA format) </h4>
* <ul>
* <li>
* <b>--min [min_1, min_2, ...] </b> discards all samples which input values are lower than min_1, min_2,...
* </li>
* <li>
* <b>--max [max_1, max_2, ...] </b> discards all samples which input values are greater than max_1, max_2,...
* </li>
* <li>
* <b>--ymin [ymin_1, ymin_2, ...] </b> discards all samples which output values are lower than min_1, min_2,...
* </li>
* <li>
* <b> --ymax [ymax_1, ymax_2, ...] </b> discards all samples which ouptut values are greater than max_1, max_2,...
* </li>
* </ul>
* <h3>Usage Examples</h3>
* <h4> Converting from MERL to plain text ALTA file format </h4>
* \verbatim
data2data --in-data data_merl --input gold-metallic-paint.binary --output gold-metallic-paint.alta --param RUSIN_TH_TD_PD --all-values
\endverbatim
* <h4> Converting from ALTA to ALTA format by keeping only positive values</h4>
* \verbatim
data2data --input gold-metallic-paint_all_values.alta --output gold-metallic-paint_only_valid.alta --param RUSIN_TH_TD_PD --ymin [0.0, 0.0, 0.0]
\endverbatim
* <h4> Filtering on input dimensions. </h4>
* \verbatim
data2data --input gold-metallic-paint_only_valid.alta --output gold-metallic-paint_filtered_tH.alta --param RUSIN_TH_TD_PD --max [1.5, 0.01, 0.01]
\endverbatim
#include <core/args.h>
#include <core/data.h>
