Commit 94b59066 authored by Ludovic Courtès's avatar Ludovic Courtès
data_brdf_slice: Mark internal fields and methods as private.
parent d9c5fc1b
......@@ -70,14 +70,15 @@ ALTA_DLL_EXPORT data* load_data(std::istream& input, const arguments& args);
class BrdfSlice : public data {
public:
private:
const int _width, _height, _slice;
vec _max, _min;
double _phi;
double* _data;
bool _reverse;
public:
BrdfSlice(const arguments& args,
int width, int height, int slice,
double* content)
......@@ -219,6 +220,8 @@ class BrdfSlice : public data {
return res;
private:
// Get data size, e.g. the number of samples to fit
int size() const
