GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
9457fdc7
9457fdc7
Laurent Belcour
Allowing to change the parametrization of the ABC model using command line argument
bab8c2e4
2
2 changed files
29 additions
1 deletion
+29
-1
sources/core/params.h
+2
-1
sources/plugins/nonlinear_function_abc/function.cpp
+27
9457fdc7
@@ -326,7 +326,8 @@ class parametrized
else
else
std
cout
"<<ERROR>> an input parametrization is already defined: "
params
get_name
_in_param
std
endl
std
cout
params
get_name
_in_param
std
endl
std
cout
"<<ERROR>> trying to change to: "
params
get_name
new_param
std
endl
std
cout
"<<ERROR>> changing to: "
params
get_name
new_param
std
endl
_in_param
new_param
9457fdc7
@@ -143,6 +143,19 @@ void abc_function::bootstrap(const data* d, const arguments& args)
_b
i
1.0
_b
i
1.0
_c
i
1.0
_c
i
1.0
if
args
is_defined
"param"
setParametrization
params
parse_input
args
"param"
else
setParametrization
params
COS_TH
if
params
dimension
input_parametrization
std
cerr
"<<ERROR>> the parametrization specifed in the file for the ABC model is incorrect"
std
endl
//! Load function specific files
@@ -175,6 +188,19 @@ bool abc_function::load(std::istream& in)
std
cerr
"<<ERROR>> parsing the stream. function name is not the next token."
std
endl
std
cerr
std
endl
return
false
return
false
in
token
if
token
compare
"#PARAM"
std
cerr
"<<ERROR>> parsing the stream. The #PARAM is not the next line defined."
std
endl
return
false
in
token
setParametrization
params
parse_input
token
if
params
dimension
std
cerr
std
endl
// Parse the lobe
// Parse the lobe
for
int
i
i
_nY
i
for
int
i
i
_nY
i
@@ -195,6 +221,7 @@ void abc_function::save_call(std::ostream& out, const arguments& args) const
if
is_alta
if
is_alta
out
"#FUNC nonlinear_function_abc"
std
endl
out
std
endl
out
"#PARAM "
params
get_name
std
endl
for
int
i
i
_nY
i
for
int
i
i
_nY
i
