Commit 7e9555ed authored by Ludovic Courtès's avatar Ludovic Courtès
data2data: Add support for "--out-data alta-binary".
parent cfff4831
/* ALTA --- Analysis of Bidirectional Reflectance Distribution Functions
Copyright (C) 2014, 2017 CNRS
Copyright (C) 2013, 2014, 2015, 2016 Inria
Copyright (C) 2013, 2014, 2015, 2016, 2017 Inria
This file is part of ALTA.
......@@ -92,6 +92,7 @@
#include <core/args.h>
#include <core/data.h>
#include <core/data_storage.h>
#include <core/params.h>
#include <core/function.h>
#include <core/fitter.h>
......@@ -150,7 +151,8 @@ int main(int argc, char** argv)
std::cout << "Optional arguments:" << std::endl;
std::cout << " --out-data [filename] Name of the plugin used to save the outputed data file" << std::endl ;
std::cout << " If none is provided, data2data will export in ALTA" << std::endl ;
std::cout << " by default." << std::endl ;
std::cout << " by default. The name \"alta-binary\" specifies ALTA's" << std::endl ;
std::cout << " native binary format." << std::endl;
std::cout << " --in-data [filename] Name of the plugin used to load the input data file" << std::endl ;
std::cout << " If none is provided, data2data will import in ALTA" << std::endl ;
......@@ -210,7 +212,13 @@ int main(int argc, char** argv)
ptr<data> d_out = plugins_manager::get_data(args["out-data"],
// "alta-binary" denotes an output format but not a class, so we need to
// special-case it.
const std::string data_class =
args["out-data"] == "alta-binary"
? "vertical_segment" : args["out-data"];
ptr<data> d_out = plugins_manager::get_data(data_class,
d_in->size(),
compute_parameters(*d_in, args),
args) ;
......@@ -362,6 +370,22 @@ int main(int argc, char** argv)
d_out->save(args["output"]);
// Special-case ALTA's binary output format. TODO: In the future, 'save'
// should no longer be a method and we'd have an output format lookup
// function in plugin_manager.
if (args["out-data"] == "alta-binary")
try
std::ofstream out;
out.exceptions(std::ios_base::failbit);
out.open(args["output"]);
save_data_as_binary(out, *d_out);
CATCH_FILE_IO_ERROR(args["output"]);
else
return EXIT_SUCCESS;
import os, sys
from subprocess import call
from os.path import basename, splitext
import filecmp
import obtain
......@@ -297,6 +298,80 @@ env.Depends(cmd01,cmd00)
AlwaysBuild(cmd01)
env.Alias('tests',cmd01)
# Convert from ALTA's text format to ALTA's binary format and back.
cmd02 = make_command_test('data2data',
['--input',
test_byproduct('gold-metallic-paint.alta'),
'--output',
test_byproduct('gold-metallic-paint-all-values.alta-bin'),
'--out-data', 'alta-binary',
'--all-values'],
'alta-to-alta-binary')
env.Depends(cmd02, cmd00)
cmd03 = make_command_test('data2data',
['--input',
'--output',
test_byproduct('gold-metallic-paint2.alta'),
'--all-values'],
'alta-binary-to-alta')
env.Depends(cmd03, cmd02)
def check_that_files_are_identical(file1, file2):
"""Return a function that checks whether FILE1 and FILE2 are identical."""
def compare_files(env, target, source):
identical = filecmp.cmp(file1, file2)
with open(str(target[0]), 'w') as log:
if identical:
log.write("PASS: '" + file1 + "' and '" + file2 + "' are identical\n")
else:
log.write("FAIL: '" + file1 + "' and '" + file2 + "' differ\n")
return 1
return compare_files
cmd04 = env.Command('data2data-alta-to-binary-to-alta.log',
check_that_files_are_identical(test_byproduct('gold-metallic-paint.alta'),
test_byproduct('gold-metallic-paint2.alta')))
env.Depends(cmd04, cmd00)
env.Depends(cmd04, cmd03)
env.Alias('tests', cmd04)
# Convert from MERL to ALTA's binary format.
cmd05 = make_command_test('data2data', ['--param RUSIN_TH_TD_PD',
'--input', test_byproduct('gold-metallic-paint.binary'),
'--in-data', 'data_merl',
'--output', test_byproduct('gold-metallic-paint2.alta-bin'),
'--all-values'],
'merl-to-alta-all-values-binary')
env.Depends(cmd05, downloadGold)
env.Alias('tests', cmd05)
cmd06 = make_command_test('data2data',
['--input',
'--output',
test_byproduct('gold-metallic-paint3.alta'),
'--all-values'],
'alta-binary-to-alta2')
env.Depends(cmd06, cmd05)
env.Alias('tests', cmd06)
cmd07 = env.Command('data2data-merl-to-alta-binary-to-alta.log',
test_byproduct('gold-metallic-paint3.alta')))
env.Depends(cmd07, cmd00)
env.Depends(cmd07, cmd06)
env.Alias('tests', cmd07)
# ADD C++ Test if the two previous tests have passed and if Catch submodule is available
if have_catch:
CXX_CATCH_TESTS = ['core/conversion-catch-1.cpp']
