Commit 79d68114 authored by Laurent Belcour's avatar Laurent Belcour
Adding parsing of the name Romain uses for ISOTROPIC_TV_PROJ_DPHI param
parent dbf08751
...@@ -22,6 +22,7 @@ std::map<params::input, const param_info> create_map() ...@@ -22,6 +22,7 @@ std::map<params::input, const param_info> create_map()
/* 2D Params */ /* 2D Params */
_map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_TH_TD, param_info("RUSIN_TH_TD", 2, "Radialy symmetric Half angle parametrization"))); _map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_TH_TD, param_info("RUSIN_TH_TD", 2, "Radialy symmetric Half angle parametrization")));
_map.insert(std::make_pair<params::input, const param_info>(params::ISOTROPIC_TV_PROJ_DPHI, param_info("ISOTROPIC_TV_PROJ_DPHI", 2, "Isoptropic projected phi parametrization without a light direction."))); _map.insert(std::make_pair<params::input, const param_info>(params::ISOTROPIC_TV_PROJ_DPHI, param_info("ISOTROPIC_TV_PROJ_DPHI", 2, "Isoptropic projected phi parametrization without a light direction.")));
_map.insert(std::make_pair<params::input, const param_info>(params::ISOTROPIC_TV_PROJ_DPHI, param_info("THETA_OUT_COS_DPHI_THETA_OUT_SIN_DPHI", 2, "Isoptropic projected phi parametrization without a light direction.")));
/* 3D Params */ /* 3D Params */
_map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_TH_TD_PD, param_info("RUSIN_TH_TD_PD", 3, "Isotropic Half angle parametrization"))); _map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_TH_TD_PD, param_info("RUSIN_TH_TD_PD", 3, "Isotropic Half angle parametrization")));
