GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
74e59925
74e59925
Laurent Belcour
Factoring half vector calculation into a single function.
2936a5b9
42 additions
43 deletions
+42
-43
sources/core/params.h
+42
-43
74e59925
@@ -17,6 +17,7 @@ class params
enum
type
enum
type
ROMEIRO_TH_TD
ROMEIRO_TH_TD
RUSIN_TH_TD
RUSIN_TH_PH_TD
RUSIN_TH_PH_TD
RUSIN_TH_TD_PD
RUSIN_TH_TD_PD
RUSIN_TH_PH_TD_PD
RUSIN_TH_PH_TD_PD
@@ -52,8 +53,8 @@ class params
//! \brief static function for input type convertion. The
\param
outvec
outvec
resulting vector should be allocated with the correct
//! resulting vector should be allocated with the correct
//! output size.
//! output size.
static
void
convert
const
double
invec
params
type
intype
static
void
convert
const
double
invec
params
type
intype
params
type
outtype
double
outvec
params
type
outtype
double
outvec
@@ -73,51 +74,23 @@ class params
switch
intype
switch
intype
// 2D Parametrizations
case
params
COS_TH_TD
half_to_cartesian
acos
invec
acos
invec
0.0
outvec
break
case
params
RUSIN_TH_TD
half_to_cartesian
invec
invec
0.0
outvec
break
// 3D Parametrization
case
params
RUSIN_TH_PH_TD
case
params
RUSIN_TH_PH_TD
// Calculate the half vector
half_to_cartesian
invec
invec
invec
2
0.0
outvec
half
sin
invec
cos
invec
half
sin
invec
sin
invec
half
2
cos
invec
outvec
sin
invec
2
outvec
outvec
2
cos
invec
2
rotate_binormal
outvec
invec
rotate_normal
outvec
invec
// Compute the out vector from the in vector and the half
// vector.
const
double
dot
outvec
half
outvec
half
outvec
2
half
2
outvec
3
outvec
dot
half
outvec
4
outvec
2.0
dot
half
outvec
5
outvec
2
2.0
dot
half
2
break
break
// 4D Parametrization
case
params
RUSIN_TH_PH_TD_PD
case
params
RUSIN_TH_PH_TD_PD
half_to_cartesian
invec
invec
invec
2
invec
3
outvec
half
sin
invec
cos
invec
half
sin
invec
sin
invec
half
2
cos
invec
// Compute the light vector using the rotation formula.
outvec
sin
invec
2
cos
invec
3
outvec
sin
invec
2
sin
invec
3
outvec
2
cos
invec
2
rotate_binormal
outvec
invec
rotate_normal
outvec
invec
// vector.
const
double
dot
outvec
half
outvec
half
outvec
2
half
2
outvec
3
outvec
dot
half
outvec
4
outvec
2.0
dot
half
outvec
5
outvec
2
2.0
dot
half
2
break
break
@@ -210,8 +183,34 @@ class params
//! \brief from the 4D definition of a half vector parametrization,
//! export the cartesian coordinates.
static
void
half_to_cartesian
double
theta_h
double
phi_h
double
theta_d
double
phi_d
double
out
double
half
3
half
sin
theta_h
cos
phi_h
half
sin
theta_h
sin
phi_h
half
2
cos
theta_h
out
sin
theta_d
cos
phi_d
out
sin
theta_d
sin
phi_d
out
2
cos
theta_d
rotate_binormal
out
theta_h
rotate_normal
out
phi_h
// vector.
const
double
dot
out
half
out
half
out
2
half
2
out
3
out
dot
half
out
4
out
2.0
dot
half
out
5
out
2
2.0
dot
half
2
//! \brief rotate a cartesian vector with respect to the normal of
\param
theta degrees.
//! theta degrees.
static
void
rotate_normal
double
vec
double
theta
static
void
rotate_normal
double
vec
double
theta
const
double
cost
cos
theta
const
double
cost
cos
theta
@@ -222,7 +221,7 @@ class params
//! \brief rotate a cartesian vector with respect to the bi-normal of
\param
theta degrees.
//! theta degrees.
static
void
rotate_binormal
double
vec
double
theta
static
void
rotate_binormal
double
vec
double
theta
const
double
cost
cos
theta
const
double
cost
cos
theta
