GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
70bd1135
70bd1135
Laurent Belcour
Updating the parametrization code
b7b79d8f
6
6 changed files
143 additions
91 deletions
+143
-91
sources/core/params.cpp
+14
-7
sources/core/params.h
+26
-26
sources/core/rational_function.cpp
+3
-13
sources/softs/data2moments/main.cpp
+58
-27
sources/softs/generate_data/main.cpp
+4
-3
sources/softs/tests/main.cpp
+38
-15
70bd1135
@@ -162,7 +162,7 @@ void params::from_cartesian(const double* invec, params::input outtype,
// 3D Parametrization
case
params
RUSIN_TH_PH_TD
outvec
acos
half
2
outvec
atan2
half
half
outvec
atan2
half
half
outvec
2
acos
half
invec
half
invec
half
2
invec
2
break
case
params
RUSIN_TH_TD_PD
@@ -172,11 +172,18 @@ void params::from_cartesian(const double* invec, params::input outtype,
diff
invec
diff
invec
diff
2
invec
2
rotate_normal
diff
outvec
rotate_binormal
diff
outvec
rotate_normal
diff
atan2
half
half
#ifdef DEBUG
std
cout
"diff* = [ "
diff
diff
diff
2
std
endl
#endif
rotate_binormal
diff
outvec
#ifdef DEBUG
std
cout
"half = [ "
half
half
half
2
std
endl
std
cout
"diff = [ "
diff
diff
diff
2
std
endl
#endif
outvec
acos
diff
2
outvec
2
atan2
diff
diff
outvec
2
atan2
diff
diff
break
case
params
ISOTROPIC_TV_TL_DPHI
outvec
acos
invec
2
@@ -193,8 +200,8 @@ void params::from_cartesian(const double* invec, params::input outtype,
diff
invec
diff
invec
diff
2
invec
2
rotate_normal
diff
outvec
rotate_binormal
diff
outvec
rotate_normal
diff
outvec
outvec
2
acos
diff
2
outvec
3
atan2
diff
diff
@@ -202,9 +209,9 @@ void params::from_cartesian(const double* invec, params::input outtype,
case
params
SPHERICAL_TL_PL_TV_PV
outvec
acos
invec
2
outvec
atan2
invec
invec
outvec
atan2
invec
invec
outvec
2
acos
invec
5
outvec
3
atan2
invec
3
invec
4
outvec
3
atan2
invec
4
invec
3
#ifdef DEBUG
std
cout
invec
2
" - acos -> "
outvec
std
endl
#endif
70bd1135
@@ -15,6 +15,12 @@
* \details
* Any \typedef function object or \typedef data object should have
* an associated parametrization.
* We use the following convention to defined the tangent, normal and
* bi-normal of the surface:
* * The normal is the upper vector (0, 0, 1)
* * The tangent direction is along x direction (1, 0, 0)
* * The bi-normal is along the y direction (0, 1, 0)
class
params
@@ -214,16 +220,10 @@ class params
const
double
cost
cos
theta
const
double
sint
sin
theta
const
double
temp
cost
vec
sint
vec
2
const
double
temp
cost
vec
sint
vec
2
#ifdef DEBUG
std
cout
acos
vec
2
std
endl
#endif
vec
2
cost
vec
2
sint
vec
#ifdef DEBUG
std
cout
acos
vec
2
std
endl
#endif
vec
temp
vec
2
cost
vec
2
sint
vec
vec
temp
static
void
print_input_params
70bd1135
@@ -219,7 +219,8 @@ double rational_function_1d::p(const vec& x, int i) const
#ifdef POLYNOMIALS
res
pow
x
k
deg
k
#else // LEGENDRE
// res *= pow(2.0*((x[k] - _min[k]) / (_max[k]-_min[k]) - 0.5), deg[k]) ;
#else
res
legendre
2.0
x
k
_min
k
_max
k
_min
k
0.5
deg
k
#endif
@@ -228,18 +229,7 @@ double rational_function_1d::p(const vec& x, int i) const
double
q
const
vec
x
int
i
const
std
vector
int
deg
index2degree
i
double
res
1.0
for
int
k
k
dimX
k
#ifdef POLYNOMIALS
res
pow
x
k
deg
k
#else // LEGENDRE
res
legendre
2.0
x
k
_min
k
_max
k
_min
k
0.5
deg
k
#endif
return
res
return
p
x
i
// Overload the function operator
70bd1135
@@ -82,35 +82,37 @@ int main(int argc, char** argv)
// Data parametrization
params
input
data_param
d
parametrization
int
d_size
params
dimension
data_param
const
int
nX
d
dimX
const
int
nY
d
dimY
double
in_angle
4
0.0
0.0
0.0
0.0
// Sample every degree
double
dtheta
0.5
M_PI
90.0
// Static data
vec
X
3
X
X
X
2
vec
Y
3
Y
Y
Y
2
vec
N
3
N
N
N
2
// Moments
vec
rawm0
d
dimY
vec
rawm1
d
dimY
for
int
theta_in
theta_in
90
theta_in
in_angle
theta_in
0.5
M_PI
90.0
vec
m_0
nY
m_0
vec
Zero
nY
vec
m_x
nY
m_0
vec
Zero
nY
vec
m_y
nY
m_0
vec
Zero
nY
vec
m_xx
nY
m_0
vec
Zero
nY
vec
m_xy
nY
m_0
vec
Zero
nY
vec
m_yy
nY
m_0
vec
Zero
nY
// Integrate over the light hemisphere
for
int
theta_out
theta_out
90
theta_out
in_angle
2
theta_out
0.5
M_PI
90.0
for
int
phi_out
phi_out
18
phi_out
for
int
phi_out
phi_out
36
phi_out
in_angle
3
phi_out
0.5
M_PI
18
0.0
in_angle
3
phi_out
2.0
M_PI
36
0.0
vec
in
d_size
cart
6
L
3
V
3
vec
in
nX
cart
6
L
3
V
3
params
convert
in_angle
params
data_param
in
params
convert
in_angle
params
params
CARTESIAN
cart
L
cart
@@ -126,30 +128,59 @@ int main(int argc, char** argv)
// Get the projected 2D coordinate
vec
xy
coord
V
L
X
Y
N
for
int
i
i
d
dimY
i
for
int
i
i
nY
i
double
val
x
i
cos
in_angle
2
rawm0
i
val
rawm1
i
val
xy
const
double
normalization
360.0
90.0
double
val
x
i
cos
in_angle
2
normalization
m_0
i
val
m_x
i
val
xy
m_y
i
val
xy
m_xx
i
val
xy
xy
m_xy
i
val
xy
xy
m_yy
i
val
xy
xy
for
int
i
i
d
dimY
i
for(int i=0; i<nY; ++i)
rawm0
i
180.0
90.0
rawm1
i
180.0
90.0
rawm0
i
m_x[i] /= m_0[i];
m_y[i] /= m_0[i];
m_xx[i] /= m_0[i];
m_xy[i] /= m_0[i];
m_yy[i] /= m_0[i];
// compute cumulants
vec
k_x
m_x
vec
k_y
m_y
vec
k_xx
m_xx
// - product(m_x,m_x);
vec
k_xy
m_xy
// - product(m_x,m_y);
vec
k_yy
m_yy
// - product(m_y,m_y);
// Output the value into the file
file
in_angle
\t
for
int
i
i
rawm0
size
i
file
rawm0
i
\t
for
int
i
i
nY
i
file
m_0
i
\t
for
int
i
i
nY
i
file
k_x
i
\t
for
int
i
i
nY
i
file
k_y
i
\t
for
int
i
i
nY
i
file
k_xx
i
\t
for
int
i
i
nY
i
file
k_xy
i
\t
for
int
i
i
nY
i
file
k_yy
i
\t
for
int
i
i
rawm1
size
i
file
rawm1
i
\t
file
std
endl
70bd1135
@@ -30,9 +30,10 @@ int main(int argc, char** argv)
//f << "#VS 2" << std::endl;
for
int
i
i
nbx
i
const
float
x
i
float
nbx
//const float y = 100.0f * exp(-10.0 * x*x) * x*x - 0.01 *x*x*x + 0.1 ;
const
float
y
1.0
1.0E-10
x
const
float
x
10.0
i
float
nbx
const
float
xp
x
9
const
float
y
1000.0
f
exp
x
x
x
x
00.1
exp
100.0
xp
xp
x
x
x
0.1
//const float y = (1.0) / (1.0E-10 + x);
f
x
\t
y
/*"\t" << y*0.9f << "\t" << y*1.1f <<*/
std
endl
70bd1135
@@ -100,16 +100,12 @@ int parametrization_tests()
std
cout
"<<DEBUG>> cartesian: "
spherical
std
endl
nb_tests_failed
std
cout
"<<DEBUG>> rusin 3d: "
rusi
std
endl
std
cout
spherical
std
endl
std
cout
std
endl
// Convert issue #1
vec
cart2
6
spherical
spherical
spherical
2
1.51844
spherical
3
2.96706
params
convert
spherical
params
params
CARTESIAN
cart2
std
cout
"<<DEBUG>> spherical before: "
spherical
std
endl
try
params
convert
spherical
params
params
RUSIN_TH_TD_PD
rusi
@@ -123,15 +119,42 @@ int parametrization_tests()
std
cout
"<<DEBUG>> spherical: "
spherical
std
endl
nb_tests_failed
std
cout
"<<DEBUG>> rusin after: "
rusi
std
endl
std
cout
"<<DEBUG>> spherical after: "
spherical
std
endl
std
cout
"<<DEBUG>> "
cart
cart2
std
endl
double
dot
cart
cart
3
cart
cart
4
cart
2
cart
5
double
dot2
cart2
cart2
3
cart2
cart2
4
cart2
2
cart2
5
std
cout
"<<DEBUG>> dot = "
dot
"dot2 = "
dot2
std
endl
std
cout
std
endl
/// Test on a known couple of directions
/// in = [0, 0, 1] out = [1, 0, 0]
// Convert from Cartesian to spherical
cart
cart
cart
2
cart
3
cart
4
cart
5
params
convert
cart
params
CARTESIAN
params
spherical
std
cout
"From cartesian to spherical"
std
endl
std
cout
spherical
std
endl
std
endl
params
convert
cart
params
CARTESIAN
params
RUSIN_TH_TD_PD
rusi
std
cout
"From cartesian to rusi"
std
endl
std
cout
rusi
std
endl
std
endl
params
convert
rusi
params
RUSIN_TH_TD_PD
params
CARTESIAN
cart
std
cout
"From rusi to cartesian"
std
endl
std
cout
cart
std
endl
std
endl
params
convert
spherical
params
params
RUSIN_TH_TD_PD
rusi
std
cout
"From spherical to rusi"
std
endl
std
cout
rusi
std
endl
std
endl
params
convert
rusi
params
RUSIN_TH_TD_PD
params
spherical
std
cout
"From rusi to spherical"
std
endl
std
cout
spherical
std
endl
std
endl
params
convert
rusi
params
RUSIN_TH_TD_PD
params
CARTESIAN
cart
std
cout
std
endl
std
cout
cart
std
endl
std
endl
params
convert
spherical
params
params
RUSIN_TH_TD_PD
rusi
std
cout
std
endl
std
cout
rusi
std
endl
std
endl
return
nb_tests_failed
