GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
53118958
Ludovic Courtès
data_storage: Separate out ALTA header parsing.
5219ee9d
86 additions
55 deletions
+86
-55
sources/core/data_storage.cpp
+86
-55
53118958
@@ -19,6 +19,48 @@
# include <endian.h>
#endif
// Key/value association list.
typedef
std
map
std
string
std
string
alist
// Read the ALTA header on INPUT and fill in RESULT as a list of key/value
// pairs.
static
void
read_header
std
istream
input
alist
result
while
input
good
if
input
peek
input
get
// consume the hash sign
std
string
line
std
getline
input
line
std
stringstream
linestream
line
// Lines starting with '# ' are real comments and we ignore them.
// Others are key/value associations that we want to use.
if
linestream
peek
std
string
key
rest
linestream
key
if
key
empty
getline
linestream
rest
if
key
"ALTA"
rest
"END HEADER"
break
else
result
key
rest
// The first non-comment line terminates the header.
else
break
void
vertical_segment
load_data_from_text
std
istream
input
vertical_segment
result
const
arguments
args
@@ -28,72 +70,61 @@ void vertical_segment::load_data_from_text(std::istream& input,
result
_nX
result
_nY
std
vector
int
vs
int
current_vs
while
input
good
std
string
line
std
getline
input
line
std
stringstream
linestream
line
// Discard incorrect lines
if
linestream
peek
linestream
ignore
std
string
comment
linestream
comment
alist
header
read_header
input
header
if
comment
std
string
"DIM"
linestream
result
_nX
result
_nY
std
stringstream
dim
header
"DIM"
dim
result
_nX
result
_nY
vs
reserve
result
dimY
for
int
k
k
result
dimY
k
vs
k
vs
reserve
result
dimY
for
int
k
k
result
dimY
k
vs
k
result
_min
resize
result
dimX
result
_max
resize
result
dimX
result
_min
resize
result
dimX
result
_max
resize
result
dimX
min
args
get_vec
"min"
result
_nX
std
numeric_limits
float
max
max
args
get_vec
"max"
result
_nX
std
numeric_limits
float
max
min
args
get_vec
"min"
result
_nX
std
numeric_limits
float
max
max
args
get_vec
"max"
result
_nX
std
numeric_limits
float
max
#ifdef DEBUG
std
cout
"<<DEBUG>> data will remove outside of "
min
max
" x-interval"
std
endl
std
cout
min
max
" x-interval"
std
endl
#endif
ymin
args
get_vec
"ymin"
result
_nY
std
numeric_limits
float
max
ymax
args
get_vec
"ymax"
result
_nY
std
numeric_limits
float
max
ymin
args
get_vec
"ymin"
result
_nY
std
numeric_limits
float
max
ymax
args
get_vec
"ymax"
result
_nY
std
numeric_limits
float
max
#ifdef DEBUG
std
cout
ymin
ymax
" y-interval"
std
endl
std
cout
ymin
ymax
" y-interval"
std
endl
#endif
for
int
k
k
result
dimX
k
result
_min
k
std
numeric_limits
double
max
result
_max
k
std
numeric_limits
double
max
else
if
comment
std
string
"VS"
int
t
linestream
t
vs
current_vs
t
current_vs
else
if
comment
std
string
"PARAM_IN"
std
string
param
linestream
param
result
_in_param
params
parse_input
param
else
if
comment
std
string
"PARAM_OUT"
std
string
param
linestream
param
result
_out_param
params
parse_output
param
continue
else
if
line
empty
for
int
k
k
result
dimX
k
result
_min
k
std
numeric_limits
double
max
result
_max
k
std
numeric_limits
double
max
result
_in_param
params
parse_input
header
"PARAM_IN"
result
_out_param
params
parse_output
header
"PARAM_OUT"
int
number
std
stringstream
line
header
"VS"
line
number
vs
current_vs
number
current_vs
// Now read the body.
while
input
good
std
string
line
std
getline
input
line
std
stringstream
linestream
line
// Discard comments and empty lines.
if
line
empty
linestream
peek
continue
