GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
45d4cb58
45d4cb58
Laurent Belcour
Cleaned code of data2brdf & Export of L2 and Linf norm when fitting
1e32f793
3
3 changed files
100 additions
164 deletions
+100
-164
sources/core/args.h
sources/core/args.h
+5
sources/core/function.cpp
+4
-1
sources/softs/data2brdf/main.cpp
+91
-163
sources/core/args.h
45d4cb58
@@ -130,6 +130,11 @@ class arguments
//std::cerr << "Underfined request to key : \"" << key << "\"" << std::endl ;
return
std
string
//! \brief update the value \a val stored under key \a key
bool
update
const
std
string
key
const
std
string
val
_map
key
val
//! \brief acces to the string value associated with the parameter
//! \a key.
45d4cb58
@@ -85,7 +85,10 @@ void function::save_header(std::ostream& out, const arguments& args) const
out
"#CMD "
args
get_cmd
std
endl
out
"#DIM "
_nX
_nY
std
endl
out
"#PARAM_IN "
params
get_name
input_parametrization
std
endl
//out << "#PARAM_OUT " << params::get_name(output_parametrization()) << std::endl;
//out << "#PARAM_OUT " << params::get_name(output_parametrization()) << std::endl;*
if
args
is_defined
"export-append"
out
args
"export-append"
std
endl
out
"#ALTA HEADER END"
std
endl
out
std
endl
45d4cb58
@@ -20,167 +20,95 @@
int
main
int
argc
char
argv
QCoreApplication
app
argc
argv
arguments
args
argc
argv
plugins_manager
manager
args
fitter
fit
manager
get_fitter
args
"fitter"
if
fit
NULL
fit
manager
get_fitter
if
args
is_defined
"available_params"
params
print_input_params
return
if
args
is_defined
"input"
std
cerr
"<<ERROR>> the input filename is not defined"
std
endl
return
if
args
is_defined
"output"
std
cerr
"<<ERROR>> the output filename is not defined"
std
endl
return
// if(fitters.size() > 0 && datas.size() > 0 && functions.size() > 0)
if
fit
NULL
fit
set_parameters
args
function
f
plugins_manager
get_function
args
d
plugins_manager
get_data
args
"data"
d
load
args
"input"
args
if
f
NULL
d
NULL
std
cerr
"<<ERROR>> no function or data object correctly defined"
std
endl
return
// Check the compatibility between the data and the function
plugins_manager
check_compatibility
d
f
args
// Start a timer
QTime
time
time
start
// Fit the data
bool
is_fitted
fit
fit_data
d
f
args
// Get the fitting duration
int
msec
time
elapsed
int
sec
msec
1000
60
int
min
msec
60000
60
int
hour
msec
3600000
// Display the result
if
is_fitted
std
cout
"<<INFO>> total time: "
hour
"h "
min
"m "
sec
"s"
std
endl
vec min, max ;
min.assign(2, args.get_float("min", 0.0f)) ;
max.assign(2, args.get_float("max", 1.5f)) ;
int nb_samples = args.get_int("nb_samples", 100) ;
double dt = (max[0]-min[0]) / nb_samples ;
std::ofstream file(args["output"].c_str(), std::ios_base::trunc);
for(double x=min[0]; x<=max[0]; x+=dt)
vec vx ; for(int i=0;i<2; ++i) { vx.push_back(x) ; }
file << x << "\t" << f->value(vx)[0] << std::endl ;
std::cout << x << "\t" << f->value(vx)[0] << std::endl ;
double
L2
f
L2_distance
d
double
Linf
f
Linf_distance
d
std
cout
"<<INFO>> L2 distance to data = "
L2
std
endl
std
cout
"<<INFO>> Linf distance to data = "
Linf
std
endl
f
save
args
"output"
args
#ifdef OLD // use brdf2gnuplot
size_t
n
args
"output"
find
std
string
gnuplot_filename
args
"output"
substr
n
gnuplot_filename
append
".gnuplot"
f->save_gnuplot(gnuplot_filename, d, args);
std
ofstream
file
gnuplot_filename
c_str
std
ios_base
trunc
for
int
i
i
d
size
i
vec
v
d
get
i
// vec y1(d->dimY()) ;
// for(int k=0; k<d->dimY(); ++k) { y1[k] = v[d->dimX() + k] ; }
vec
y2
f
value
v
for
int
u
u
d
dimX
u
file
v
u
\t
for
int
u
u
d
dimY
u
file
y2
u
\t
file
std
endl
file
close
std
string
error_filename
args
"output"
substr
n
error_filename
append
".errorplot"
file
open
error_filename
c_str
std
ios_base
trunc
for
int
i
i
d
size
i
vec
v
d
get
i
vec
y1
d
dimY
for
int
k
k
d
dimY
k
y1
k
v
d
dimX
k
vec
y2
f
value
v
for
int
u
u
d
dimX
u
file
v
u
\t
for
int
u
u
d
dimY
u
file
y2
u
y1
u
\t
file
std
endl
file
close
std
string
linerror_filename
args
"output"
substr
n
linerror_filename
append
".linearerrorplot"
file
open
linerror_filename
c_str
std
ios_base
trunc
for
int
i
i
d
size
i
vec
v
d
get
i
vec
y1
d
dimY
for
int
k
k
d
dimY
k
y1
k
0.5
v
d
dimX
k
v
d
dimX
d
dimY
k
vec
y2
f
value
v
file
i
\t
for
int
u
u
d
dimY
u
file
y2
u
y1
u
\t
file
std
endl
file
close
#endif
return
else
std
cout
"<<ERROR>> unable to fit the data"
std
endl
return
else
std
cout
"<<ERROR>> no fitter loaded, please check your command line arguments"
std
endl
return
arguments
args
argc
argv
plugins_manager
manager
args
fitter
fit
manager
get_fitter
args
"fitter"
if
fit
NULL
fit
manager
get_fitter
if
args
is_defined
"available_params"
params
print_input_params
return
if
args
is_defined
"input"
std
cerr
std
endl
return
if
args
is_defined
"output"
std
cerr
std
endl
return
if
fit
NULL
fit
set_parameters
args
function
f
plugins_manager
get_function
args
d
plugins_manager
get_data
args
"data"
d
load
args
"input"
args
if
f
NULL
d
NULL
std
cerr
std
endl
return
plugins_manager
check_compatibility
d
f
args
// Start a timer
QTime
time
time
start
// Fit the data
bool
is_fitted
fit
fit_data
d
f
args
int
msec
time
elapsed
int
sec
msec
1000
60
int
min
msec
60000
60
int
hour
msec
3600000
if
is_fitted
std
cout
hour
"h "
min
"m "
sec
"s"
std
endl
double
L2
f
L2_distance
d
double
Linf
f
Linf_distance
d
std
cout
L2
std
endl
std
cout
Linf
std
endl
std
stringstream
append
// Append informations to the export
if
args
is_defined
"export-append"
append
args
"export-append"
append
"#L2 "
L2
std
endl
append
"#LINF "
Linf
args
update
"export-append"
append
str
f
save
args
"output"
args
return
else
std
cout
std
endl
return
else
std
cout
std
endl
return
