Commit 3b6aa615 authored by Laurent Belcour's avatar Laurent Belcour
Adding a convertion tool between vertical segment objects.
Updating the parametrizations to be more complete.
Changing the data object to handle cosine correction.
parent b77123ed
......@@ -22,22 +22,24 @@ class data : public parametrized
virtual void load(const std::string& filename) = 0 ;
virtual void load(const std::string& filename, const arguments& args) = 0 ;
// Save the data to a file
virtual void save(const std::string& filename) const
std::ofstream file(filename.c_str(), std::ios_base::trunc);
file << "#DIM " << _nX << " " << _nY << std::endl;
for(int i=0; i<size(); ++i)
vec x = this->get(i);
for(int j=0; j<_nX+_nY; ++j)
file << x[j] << "\t";
file << std::endl;
file.close();
file << "PARAM_IN " << params::get_name(input_parametrization()) << std::endl;
file << "PARAM_OUT " << params::get_name(output_parametrization()) << std::endl;
file << std::endl;
file.close();
// Acces to data
virtual vec get(int i) const = 0 ;
......@@ -430,6 +430,7 @@ bool compound_function::load(std::istream& in)
nb_good++;
std::cout << "<<DEBUG>> number of correct function loaded in compound: " << nb_good << " / " << fs.size() << std::endl;
return nb_good > 0;
......@@ -32,6 +32,7 @@ std::map<params::input, const param_info> create_map()
_map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_VH, param_info("RUSIN_VH", 3, "Vector representation of the Half angle only")));
_map.insert(std::make_pair<params::input, const param_info>(params::SCHLICK_VK, param_info("SCHLICK_VH", 3, "Vector representation of the Back angle only")));
_map.insert(std::make_pair<params::input, const param_info>(params::ISOTROPIC_TL_TV_PROJ_DPHI, param_info("ISOTROPIC_TL_TV_PROJ_DPHI", 3, "Isoptropic projected phi parametrization.")));
_map.insert(std::make_pair<params::input, const param_info>(params::SCHLICK_TL_TK_PROJ_DPHI, param_info("SCHLICK_TL_TK_PROJ_DPHI", 3, "Isoptropic projected phi parametrization centered around the back vector.")));
/* 4D Params */
_map.insert(std::make_pair<params::input, const param_info>(params::RUSIN_TH_PH_TD_PD, param_info("RUSIN_TH_PH_TD_PD", 4, "Complete Half angle parametrization")));
......@@ -173,6 +174,9 @@ void params::to_cartesian(const double* invec, params::input intype,
outvec[5] = cos(invec[0]);
break;
case SCHLICK_TL_TK_PROJ_DPHI:
NOT_IMPLEMENTED();
break;
case RETRO_TL_TVL_PROJ_DPHI:
const double theta = std::fabs(sqrt(invec[1]*invec[1] + invec[2]*invec[2]) - invec[0]);
......@@ -354,6 +358,19 @@ void params::from_cartesian(const double* invec, params::input outtype,
outvec[0] = theta_l;
outvec[1] = theta_v * cos(dphi);
outvec[2] = theta_v * sin(dphi);
break;
const double vkx = invec[0]-invec[3];
const double vky = invec[1]-invec[4];
const double vkz = invec[2]+invec[5];
const double norm = sqrt(vkx*vkx + vky*vky + vkz*vkz);
const double theta_k = acos(vkz / norm);
const double dphi = atan2(invec[4], invec[3]) - atan2(vky/norm, vkx/norm);
outvec[0] = acos(invec[5]);
outvec[1] = theta_k * cos(dphi);
outvec[2] = theta_k * sin(dphi);
break;
......@@ -52,9 +52,9 @@ class params
SCHLICK_TK_PK, /*!< Schlick's back vector parametrization */
SCHLICK_VK, /*!< Schlick's back vector */
SCHLICK_TK_PROJ_DPHI, /*!< 2D Parametrization where the phi component is projected and
SCHLICK_TL_TK_PROJ_DPHI,/*!< 3D Parametrization where the phi component is projected and
the parametrization is centered around the back direction.
\f$[x, y] = [\theta_K \cos(\phi_K), \theta_K \sin(\phi_K)]\f$*/
\f$[\theta_L, x, y] = [\theta_L, \theta_K \cos(\phi_K), \theta_K \sin(\phi_K)]\f$*/
COS_TK, /*!< Schlick's back vector dot product with the normal */
......@@ -118,6 +118,15 @@ class params
//! \brief look for the string associated with a parametrization
//! type.
static std::string get_name(const params::input param);
//! type.
//! \todo Finish this implementation. It requires another static
//! object.
static std::string get_name(const params::output param)
return std::string("UNKNOWN_OUTPUT");
//! \brief static function for input type convertion. This
//! function allocate the resulting vector.
......@@ -374,7 +374,7 @@ function* plugins_manager::get_function(const arguments& args)
// Correction of the data by 1/cosine(theta_L)
if(args.is_defined("data-correct-cosine"))
......@@ -382,7 +382,7 @@ function* plugins_manager::get_function(const arguments& args)
func = new product_function(cosine, dynamic_cast<nonlinear_function*>(func));
// End of correction
return func;
data* plugins_manager::get_data(const std::string& n)
......@@ -98,22 +98,29 @@ void vertical_segment::load(const std::string& filename, const arguments& args)
linestream >> v[i] ;
double factor = 1.0;
double cart[6];
params::convert(&v[0], input_parametrization(), params::CARTESIAN, cart);
factor = 1.0/cart[5];
if(cart[5] > 0.0 && cart[2] > 0.0)
factor = 1.0/cart[5]*cart[2];
else
continue;
for(int i=0; i<dimY(); ++i)
linestream >> v[dimX() + i];
// v[dimX() + i] /= factor;
// Check if the data containt a vertical segment around the mean
......@@ -181,6 +188,9 @@ void vertical_segment::load(const std::string& filename, const arguments& args)
save("/tmp/data-corrected.dat");
std::cout << "<<INFO>> loaded file \"" << filename << "\"" << std::endl ;
std::cout << "<<INFO>> data inside " << _min << " ... " << _max << std::endl ;
......@@ -160,7 +160,7 @@ vec diffuse_function::parametersJacobian(const vec& x) const
void diffuse_function::bootstrap(const data* d, const arguments& args)
// Set the diffuse component
if(params::is_cosine_weighted(d->output_parametrization()))
......@@ -185,12 +185,12 @@ void diffuse_function::bootstrap(const data* d, const arguments& args)
else
vec x0 = d->get(0);
for(int i=0; i<d->dimY(); ++i)
_kd[i] = x0[d->dimX() + i];
_kd[i] = std::numeric_limits<double>::max();
for(int i=1; i<d->size(); ++i)
for(int i=0; i<d->size(); ++i)
vec xi = d->get(i);
for(int j=0; j<d->dimY(); ++j)
#include <core/function.h>
#include <core/fitter.h>
#include <core/plugins_manager.h>
#include <core/vertical_segment.h>
#include <iostream>
#include <vector>
......@@ -70,25 +71,61 @@ int main(int argc, char** argv)
// Import data
data* d_in = NULL ;
d_in = plugins_manager::get_data(args["in-data"]) ;
d_in->load(args["input"]);
d_in->load(args["input"], args);
data* d_out = NULL;
d_out = plugins_manager::get_data(args["out-data"]) ;
if(d_out->dimY() != d_in->dimY())
if(d_in == NULL && d_out == NULL)
std::cerr << "<<ERROR>> data types have incompatible output dimensions" << std::endl;
std::cerr << "<<ERROR>> cannot import or export data" << std::endl ;
return 1;
if(d_in != NULL && d_out != NULL)
if(dynamic_cast<vertical_segment*>(d_out) != NULL)
params::input param = params::parse_input(args["param"]);
if(param == params::UNKNOWN_INPUT)
std::cerr << "<<ERROR>> unable to parse the parametrization" << std::endl;
return -1;
d_out->setParametrization(param);
d_out->setDimX(params::dimension(param));
d_out->setDimY(d_in->dimY());
std::cout << "<<INFO>> output DIM = " << d_out->dimX() << ", " << d_out->dimY() << std::endl;
vec temp(d_out->dimX() + d_out->dimY());
for(int i=0; i<d_in->size(); ++i)
// Copy the input vector
vec x = d_in->get(i);
params::convert(&x[0], d_in->parametrization(), d_out->parametrization(), &temp[0]);
for(int j=0; j<d_in->dimY(); ++j)
temp[d_out->dimX() + j] = x[d_in->dimX() + j];
d_out->set(temp);
else
vec temp(d_in->dimX());
for(int i=0; i<d_out->size(); ++i)
vec x = d_out->get(i);
params::convert(&x[0], d_out->parametrization(), d_in->parametrization(), &temp[0]);
vec y = d_in->value(temp);
......@@ -98,14 +135,7 @@ int main(int argc, char** argv)
d_out->set(x);
d_out->save(args["output"]);
return 0 ;
else
return 1;
return 0 ;
......@@ -36,7 +36,7 @@ int main(int argc, char** argv)
if(args.is_defined("help")) {
std::cout << "Usage: data2moments --input data.file --output gnuplot.file --data loader.so" << std::endl ;
std::cout << " -> input, output and data are mandatory parameters" << std::endl ;
std::cout << "Compute the statistical moments, up to order 4, on the data file" << std::endl ;
return 0 ;
......@@ -107,6 +107,7 @@ int main(int argc, char** argv)
vec k_yyyy(nY);
#ifndef OLD
// Number of elements per dimension
std::vector<int> dim;
if(args.is_defined("dim"))
......@@ -156,7 +157,6 @@ int main(int argc, char** argv)
// For the global index i of the sample, compute the index in the various
// dimensions and then compute the position within the dimension. All the
// samples are taken uniformly.
// \todo Ad Metropolis integration
int indices[nX];
int global = i;
for(int k=0; k<nX; ++k)
......@@ -228,7 +228,7 @@ int main(int argc, char** argv)
#ifdef NOT
k_xxxx = m_xxxx - 4*m_xxx*m_x - 3*m_xx*m_xx + 12*m_xx*m_x*m_x - 6*m_x*m_x*m_x*m_x;
k_xxxy = m_xxxy - 3*m_xxy*m_x - m_xxx*m_y - 3*m_xx*m_xy + 6*m_xx*m_x*m_y + 6*m_xy*m_x*m_x - 6*m_x*m_x*m_x*m_y;
k_xxyy = m_xxyy - 2*m_xxy*m_y - m_xyy*m_x - 2*m_xy*m_xy - m_xx*m_yy + 8*m_xy*m_x*m_y + 2*m_xx*m_y*m_y + 2*m_yy*m_x*m_x - 6*m_x*m_x*m_y*m_y;
k_xxyy = m_xxyy - 2*m_xxy*m_y - 2*m_xyy*m_x - 2*m_xy*m_xy - m_xx*m_yy + 8*m_xy*m_x*m_y + 2*m_xx*m_y*m_y + 2*m_yy*m_x*m_x - 6*m_x*m_x*m_y*m_y;
k_xyyy = m_xyyy - 3*m_xyy*m_y - m_yyy*m_x - 3*m_yy*m_xy + 6*m_yy*m_x*m_y + 6*m_xy*m_y*m_y - 6*m_x*m_y*m_y*m_y;
k_yyyy = m_yyyy - 4*m_yyy*m_y - 3*m_yy*m_yy + 12*m_yy*m_y*m_y - 6*m_y*m_y*m_y*m_y;
#endif
