GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
alta
alta
3ae862f9
3ae862f9
Laurent Belcour
[Fix] Correction for the output of UTIA data files
8d794d25
sources/plugins/data_io/utia.cpp
3ae862f9
@@ -131,7 +131,7 @@ public:
for
int
i
i
H
i
for
int
i
i
H
i
for
int
j
j
W
j
for
int
j
j
W
j
int
indexUTIA
i
W
j
int
indexUTIA
i
W
j
int
indexEXR
H
i
W
j
int
indexEXR
i
W
j
temp
3
indexEXR
Bd
indexUTIA
nPerPlane
temp
3
indexEXR
Bd
indexUTIA
nPerPlane
temp
3
indexEXR
Bd
indexUTIA
nPerPlane
temp
3
indexEXR
Bd
indexUTIA
nPerPlane
temp
3
indexEXR
2
Bd
indexUTIA
2
nPerPlane
temp
3
indexEXR
2
Bd
indexUTIA
2
nPerPlane
@@ -296,9 +296,9 @@ public:
virtual
void
set
int
i
const
vec
x
virtual
void
set
int
i
const
vec
x
assert
x
size
parametrization
dimY
const
vec
y
x
tail
parametrization
dimY
for
int
isp
isp
planes
isp
for
int
isp
isp
planes
isp
Bd
isp
nPerPlane
i
x
isp
Bd
isp
nPerPlane
i
y
isp
@@ -308,7 +308,9 @@ public:
ALTA_DLL_EXPORT
provide_data
size_t
size
const
parameters
params
ALTA_DLL_EXPORT
provide_data
size_t
size
const
parameters
params
const
arguments
const
arguments
return
new
UTIA
params
return
new
UTIA
alta
parameters
4
3
params
SPHERICAL_TL_PL_TV_PV
params
RGB_COLOR
ALTA_DLL_EXPORT
load_data
std
istream
input
const
arguments
args
ALTA_DLL_EXPORT
load_data
std
istream
input
const
arguments
args
