Commit 38d175b8 authored by Laurent Belcour's avatar Laurent Belcour
Adding Building of rational function and fitter using SCons
parent 8373bf1f
...@@ -11,7 +11,7 @@ execfile('obtain_ceres.py') ...@@ -11,7 +11,7 @@ execfile('obtain_ceres.py')
# QuadProg++ # QuadProg++
qp_target = 'build' + os.sep + 'lib' + os.sep + 'quaprog++' qp_target = 'build' + os.sep + 'lib' + os.sep + 'quadprog++'
qp_base = 'quadprog++' + os.sep qp_base = 'quadprog++' + os.sep
qp_sources = [qp_base + 'Array.cc', qp_base + 'QuadProg++.cc'] qp_sources = [qp_base + 'Array.cc', qp_base + 'QuadProg++.cc']
env.Append(CPPPATH = ['build' + os.sep + 'include']) env.Append(CPPPATH = ['build' + os.sep + 'include'])
...@@ -35,7 +35,7 @@ void rational_function_1d::update(const vec& in_a, ...@@ -35,7 +35,7 @@ void rational_function_1d::update(const vec& in_a,
a.resize(in_a.size()) ; a.resize(in_a.size()) ;
b.resize(in_b.size()) ; b.resize(in_b.size()) ;
#define NORMALIZE //#define NORMALIZE
#ifdef NORMALIZE #ifdef NORMALIZE
const double b0 = (std::abs(in_b[0]) > 1.0E-10) ? in_b[0] : 1.0; const double b0 = (std::abs(in_b[0]) > 1.0E-10) ? in_b[0] : 1.0;
# Building fitters # Building fitters
SConscript('nonlinear_fitter_ceres/SConscript') SConscript('nonlinear_fitter_ceres/SConscript')
SConscript('rational_fitter_quadprog/SConscript')
# Building functions # Building functions
SConscript('nonlinear_function_diffuse/SConscript') SConscript('nonlinear_function_diffuse/SConscript')
SConscript('nonlinear_function_blinn/SConscript') SConscript('nonlinear_function_blinn/SConscript')
SConscript('nonlinear_function_retroblinn/SConscript') SConscript('nonlinear_function_retroblinn/SConscript')
SConscript('rational_function_legendre/SConscript')
SConscript('rational_function_chebychev/SConscript')
env = Environment()
env.Append(CPPPATH = ['../../../external/quadprog++', '../../../external/build/include', '../../'])
env.Append(LIBPATH = ['../../../external/build/lib', '../../build'])
sources = ['rational_fitter.cpp']
libs = ['-lcore', '-lquadprog++']
env.SharedLibrary('../../build/rational_fitter_quadprog', sources, LIBS=libs)
env = Environment()
env.Append(CPPPATH = ['../../../external/build/include', '../../'])
sources = ['rational_function.cpp']
libs = ['-lcore']
env.SharedLibrary('../../build/rational_function_chebychev', sources, LIBS=libs)
env = Environment()
libs = ['-lcore']
env.SharedLibrary('../../build/rational_function_legendre', sources, LIBS=libs)
Supports Markdown
