_map.insert(std::make_pair<params::input,constparam_info>(params::COS_TH_TD,param_info("COS_TH_TD",2,"Cosines of the elevation angles of the Half angle parametrization")));
_map.insert(std::make_pair<params::input,constparam_info>(params::ISOTROPIC_TV_PROJ_DPHI,param_info("ISOTROPIC_TV_PROJ_DPHI",2,"Isoptropic projected phi parametrization without a light direction.")));
_map.insert(std::make_pair<params::input,constparam_info>(params::STARK_2D,param_info("STARK_2D",2,"Stark parametrization H, B but without third component.")));
_map.insert(std::make_pair<params::input,constparam_info>(params::NEUMANN_2D,param_info("NEUMANN_2D",2,"Neumann parametrization H, B but without third component.")));
