Commit 2efa24ee authored by Laurent Belcour's avatar Laurent Belcour
[CMake] Adding utility function to add command line tests
parent f5a83f10
......@@ -67,6 +67,18 @@ function(alta_add_soft name sources)
target_link_libraries(${name} core)
endfunction(alta_add_soft)
function(alta_test)
set(options OPTIONAL)
set(oneValueArgs NAME)
set(multiValueArgs COMMAND)
cmake_parse_arguments(TEST "${options}" "${oneValueArgs}" "${multiValueArgs}" ${ARGN})
add_test(NAME ${TEST_NAME} COMMAND ${TEST_COMMAND}
WORKING_DIRECTORY "${CMAKE_BINARY_DIR}/tests")
set_tests_properties("${TEST_NAME}"
PROPERTIES ENVIRONMENT "ALTA_PLUGIN_PATH=${CMAKE_BINARY_DIR}/plugins")
endfunction(alta_test)
function(alta_test_unit name sources)
add_executable(${name} sources/tests/${sources})
......@@ -276,14 +288,20 @@ add_test(NAME "data2stats_kirby"
"--ref" "${CMAKE_SOURCE_DIR}/sources/tests/Kirby2.dat"
foreach(fitter IN ITEMS ${nonlinear_fitters})
add_test(NAME "data2brdf_pinkfelt_${fitter}_blinn"
# add_test(NAME "data2brdf_pinkfelt_${fitter}"
# COMMAND "data2brdf"
# "--input" "${CMAKE_SOURCE_DIR}/data/brdf/pink-felt-1d.alta"
# "--output" "pink-felt-1d-${fitter}-blinn.func"
# "--fitter" "nonlinear_fitter_${fitter}"
# "--func" "[nonlinear_function_diffuse, nonlinear_function_blinn]"
# WORKING_DIRECTORY "${CMAKE_BINARY_DIR}/tests")
alta_test(NAME "data2brdf_pinkfelt_${fitter}"
COMMAND "data2brdf"
"--output" "pink-felt-1d-ceres-blinn.func"
"--func" "[nonlinear_function_diffuse, nonlinear_function_blinn]")
endforeach()
# add a target to generate API documentation with Doxygen
