Commit 2bb701f5 authored by Laurent Belcour's avatar Laurent Belcour
Updating documentation and adding the reparametrization
parent 91020271
......@@ -161,7 +161,18 @@ struct CompoundFunctor: Eigen::DenseFunctor<double>
vec _fy = vec::Zero(f->dimY());
for(int i=0; i<_index+1; ++i)
_fy += (*(*_f)[i])(_x);
const nonlinear_function* f = (*_f)[i];
if(f->input_parametrization() != _d->input_parametrization())
vec x(f->dimX());
params::convert(&_x[0], _d->input_parametrization(), f->input_parametrization(), &x[0]);
_fy += (*f)(x);
else
_fy += (*f)(_x);
// Should add the resulting vector completely
......@@ -202,7 +213,19 @@ struct CompoundFunctor: Eigen::DenseFunctor<double>
// Get the associated jacobian
vec _jac = f->parametersJacobian(xi);
vec _jac;
vec x(f->dimX());
params::convert(&xi[0], _d->input_parametrization(), f->input_parametrization(), &x[0]);
_jac = f->parametersJacobian(x);
else
// Fill the columns of the matrix
for(int j=0; j<f->nbParameters(); ++j)
......@@ -14,6 +14,27 @@
/*! \brief A fitter for non-linear BRDF models that uses Eigen's
* Levenberg-Marquardt solver.
* \ingroup plugins
* You will need the Eigen unsupported library (available with mercurial)
* <ul>
* <li>Eigen latest version.</li>
* </ul>
* You need to provide your own eigen.prf file for qmake to generate the correct
* Makefile or Visual Studio solution. In particular this configuration file
* should provide:
* <pre>
* INCLUDEPATH += [path-to-eigen-include]
* </pre>
* <h3>Plugin parameters</h3>
* <ul>
* <li><b>--fit-compound</b> to control how the fitting procedure is
* done. If this flag is set, any compound function will be decomposed
* during the fit. The fitting will be done incrementally. <b>in progress</b></li>
* </ul>
class nonlinear_fitter_eigen: public fitter
