Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 2b2ba52f authored by Laurent Belcour's avatar Laurent Belcour
[CMake] Update test suite to use the generic python command
parent 4dbc3513
......@@ -321,13 +321,13 @@ endforeach()
if(PYTHONLIBS_FOUND AND PYBIND_FOUND)
alta_test_python(NAME "python_test_arguments"
COMMAND "python3" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-arguments.py")
COMMAND "python" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-arguments.py")
alta_test_python(NAME "python_test_vec"
COMMAND "python3" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-vec.py")
COMMAND "python" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-vec.py")
alta_test_python(NAME "python_test_function"
COMMAND "python3" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-python-function.py")
COMMAND "python" "${CMAKE_SOURCE_DIR}/sources/tests/python/test-python-function.py")
endif()
# add a target to generate API documentation with Doxygen
