GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
1963695d
1963695d
Laurent Belcour
Changing the name of the function, it is only returning the total memory on the
system. Updated the computation of the memory cost.
1ec36b2a
3
3 changed files
11 additions
11 deletions
+11
-11
sources/core/plugins_manager.cpp
+2
-2
sources/core/plugins_manager.h
+2
-2
sources/plugins/rational_fitter_parallel/rational_fitter.cpp
+7
-7
1963695d
@@ -162,7 +162,7 @@ fitter* plugins_manager::get_fitter(const std::string& n) const
// \todo implement the Darwin (MACOS) version.
#ifdef WIN32
#include <windows.h>
size_t
plugins_manager
get_
available
_memory
size_t
plugins_manager
get_
system
_memory
MEMORYSTATUSEX
status
status
dwLength
sizeof
status
@@ -171,7 +171,7 @@ size_t plugins_manager::get_available_memory()
#else
#include <unistd.h>
size_t
plugins_manager
get_
available
_memory
size_t
plugins_manager
get_
system
_memory
long
pages
sysconf
_SC_PHYS_PAGES
long
page_size
sysconf
_SC_PAGE_SIZE
1963695d
@@ -32,10 +32,10 @@ class plugins_manager
get_data
const
std
string
n
const
fitter
get_fitter
const
std
string
n
const
//! \brief Provide a measure of how much
free memory is left
on the system.
memory there is
on the system.
//! \details It permits to know is one can allocate more memory for a fitting
//! procedure for example.
static
size_t
get_
available
_memory
static
size_t
get_
system
_memory
private:
//data
1963695d
@@ -61,21 +61,21 @@ bool rational_fitter_parallel::fit_data(const data* dat, function* fit)
// Allocate enough processor to run fully in parallel, but account for
// the fact that each thread will require its own memory.
size_t
need_memory
i
d
size
2
sizeof
double
size_t
avai_memory
plugins_manager
get_
available
_memory
int
nb_cores
avai_memory
need_memory
size_t
need_memory
3
i
d
size
2
2
i
2
d
dimY
d
size
sizeof
double
size_t
avai_memory
plugins_manager
get_
system
_memory
int
nb_cores
60
avai_memory
100
need_memory
nb_cores
std
min
int
nb_cores
omp_get_num_procs
if
nb_cores
std
cerr
"<<ERROR>> not enough memory to perform the fit"
std
endl
#if
n
def DEBUG
std
cout
"<<DEBUG>> "
need_memory
1024
"MB required / "
avai_memory
1024
"MB available"
std
endl
#ifdef DEBUG
std
cout
"<<DEBUG>> "
need_memory
1024
1024
"MB required / "
avai_memory
1024
1024
"MB available"
std
endl
#endif
return
false
#if
n
def DEBUG
#ifdef DEBUG
std
cout
"<<DEBUG>> will use "
nb_cores
" threads to compute the quadratic programs"
std
endl
#endif
omp_set_num_threads
nb_cores
