Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit 091fda67 authored by PACANOWSKI Romain's avatar PACANOWSKI Romain
added the output param
parent 6f6a1703
...@@ -38,6 +38,12 @@ parametrizations (like LAB color space). Fitting will be performed ...@@ -38,6 +38,12 @@ parametrizations (like LAB color space). Fitting will be performed
independantly of the data and function output space. They only need independantly of the data and function output space. They only need
to match in size. to match in size.
\verbatim
INV_STERADIAN, // A BRDF which unit is sr^{-1}
INV_STERADIAN_COSINE_FACTOR, // A BRDF multiplied by the cosine factor, unit is still sr^{-1}
\endverbatim
<h2>Input file format</h2> <h2>Input file format</h2>
For a text data file with <em>n</em> data entries where the input domain has <em>N</em> dimensions and a <em>input_param</em> parametrization and the output domain has <em>P</em> dimensions and a <em>output_param</em> parametrization, our file format is the following: For a text data file with <em>n</em> data entries where the input domain has <em>N</em> dimensions and a <em>input_param</em> parametrization and the output domain has <em>P</em> dimensions and a <em>output_param</em> parametrization, our file format is the following:
