Commit 08bb7775 authored by Laurent Belcour's avatar Laurent Belcour
Adding a disclaimer on the website.
parent 10551cfc
...@@ -21,3 +21,5 @@ MULTILINE_CPP_IS_BRIEF = NO ...@@ -21,3 +21,5 @@ MULTILINE_CPP_IS_BRIEF = NO
HTML_STYLESHEET = doxygen.css HTML_STYLESHEET = doxygen.css
IMAGE_PATH = ./images IMAGE_PATH = ./images
EXCLUDE_PATTERNS = params.* *retro*
\mainpage A BRDF analysis library \mainpage A BRDF analysis library
<center style="color:red">
We have not released ALTA yet, you will not have access to source code and
data. They will be shipped afterwards. This page was generated automatically
using doxygen. Consequently, you could experience broken links.
</center>
<h2>Description</h2> <h2>Description</h2>
ALTA is a software library to analyse, fit and understand BRDFs. It ALTA is a software library to analyse, fit and understand BRDFs. It
provides a set of command line softwares to fit measured data to analytical provides a set of command line softwares to fit measured data to analytical
