Commit 074a041f authored by PACANOWSKI Romain's avatar PACANOWSKI Romain
Indentation
parent c9b00322
...@@ -242,28 +242,28 @@ function* plugins_manager::get_function(const arguments& args) ...@@ -242,28 +242,28 @@ function* plugins_manager::get_function(const arguments& args)
//! create a <em>compound</em> class to store multiple //! create a <em>compound</em> class to store multiple
//! functions in it. //! functions in it.
compound_function* compound = new compound_function(); compound_function* compound = new compound_function();
//! For each args_vec element, create a function object and add //! For each args_vec element, create a function object and add
//! it to the compound one. //! it to the compound one.
for(unsigned int i=0; i<args_vec.size(); ++i) for(unsigned int i=0; i<args_vec.size(); ++i)
std::string n("--func ");
n.append(args_vec[i]);
#ifdef DEBUG
std::cout << "<<DEBUG>> load function with args: " << n << std::endl;
#endif
arguments temp_args = arguments::create_arguments(n);
function* f = get_function(temp_args);
if(dynamic_cast<nonlinear_function*>(f) == NULL)
std::string n("--func "); std::cerr << "<<ERROR>> only non-linear function care compatible with a compound" << std::endl;
n.append(args_vec[i]); }
#ifdef DEBUG else
std::cout << "<<DEBUG>> load function with args: " << n << std::endl; {
#endif compound->push_back(dynamic_cast<nonlinear_function*>(f), temp_args);
else
//! return the compound class //! return the compound class
func = compound; func = compound;
...@@ -289,50 +289,51 @@ function* plugins_manager::get_function(const arguments& args) ...@@ -289,50 +289,51 @@ function* plugins_manager::get_function(const arguments& args)
// Treat the case of the Fresnel // Treat the case of the Fresnel
if(args.is_defined("fresnel")) if(args.is_defined("fresnel"))
// Cast into a non linear function, only those are permitted to use // Cast into a non linear function, only those are permitted to use
// a Fresnel term. // a Fresnel term.
nonlinear_function* nl_func = dynamic_cast<nonlinear_function*>(func); nonlinear_function* nl_func = dynamic_cast<nonlinear_function*>(func);
if(nl_func == NULL) if(nl_func == NULL)
std::cerr << "<<ERROR>> only non-linear function are permitted to use Fresnel" << std::endl; std::cerr << "<<ERROR>> only non-linear function are permitted to use Fresnel" << std::endl;
return func; return func;
std::cout << "<<DEBUG>> multiplying by a Fresnel term" << std::endl; std::cout << "<<DEBUG>> multiplying by a Fresnel term" << std::endl;
if(args.is_vec("fresnel"))
std::string temp = args["fresnel"];
n.append(temp.substr(1, temp.size()-2));
else
std::string fname = args["fresnel"];
if(fname.empty()) // Nothing to do except print error, no plugin defined
std::cerr << "<<ERROR>> Fresnel plugin not defined" << std::endl;
std::cerr << "<<ERROR>> using --fresnel alone is not permitted" << std::endl;
return func;
else // Case where the fresnel parameters is only the plugin filename
n.append(fname);
nonlinear_function* func_fres = dynamic_cast<nonlinear_function*>(get_function(arguments::create_arguments(n)));
if(func_fres != NULL)
return new product_function(nl_func, func_fres);
else
std::cerr << "<<ERROR>> the right part of the product is not a nonlinear function. Will use only the left part." << std::endl;
return func;
else
return func;
n.append(fname);
else
return func;
// Correction of the data by 1/cosine(theta_L) // Correction of the data by 1/cosine(theta_L)
if(args.is_defined("data-correct-cosine")) if(args.is_defined("data-correct-cosine"))
...@@ -342,6 +343,8 @@ function* plugins_manager::get_function(const arguments& args) ...@@ -342,6 +343,8 @@ function* plugins_manager::get_function(const arguments& args)
// End of correction // End of correction
ptr<data> plugins_manager::get_data(const std::string& n) ptr<data> plugins_manager::get_data(const std::string& n)
