GitLab
Support
Community forum
Keyboard shortcuts
A
alta
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
alta
alta
02008951
Laurent Belcour
Does compile under Windows
da34b627
6
6 changed files
25 additions
12 deletions
+25
-12
sources/core/args.h
sources/core/args.h
+1
-1
sources/core/common.cpp
+5
-5
sources/core/common.h
+13
sources/core/function.cpp
+1
-1
sources/core/rational_function.cpp
+2
-2
sources/core/vertical_segment.cpp
+3
-3
sources/core/args.h
02008951
@@ -151,7 +151,7 @@ class arguments
float
get_float
const
std
string
key
float
default_value
0.0
f
const
float
get_float
const
std
string
key
float
default_value
0.0
f
const
if
_map
count
key
if
_map
count
key
return
atof
_map
find
key
second
c_str
return
float
atof
_map
find
key
second
c_str
else
else
return
default_value
return
default_value
02008951
@@ -3,7 +3,7 @@
@@ -3,7 +3,7 @@
double
norm
const
vec
a
double
norm
const
vec
a
double
norm
0.0
double
norm
0.0
for
unsigned
int
i
i
a
size
i
for
int
i
i
a
size
i
norm
a
i
a
i
norm
a
i
a
i
@@ -14,13 +14,13 @@ vec normalize(const vec& a)
vec
b
a
size
vec
b
a
size
double
norm
0.0
double
norm
0.0
for
unsigned
int
i
i
a
size
i
for
int
i
i
a
size
i
norm
a
i
a
i
norm
a
i
a
i
norm
sqrt
norm
norm
sqrt
norm
for
unsigned
int
i
i
a
size
i
for
int
i
i
a
size
i
b
i
a
i
norm
b
i
a
i
norm
@@ -33,7 +33,7 @@ double dot(const vec& a, const vec& b)
assert
a
size
b
size
assert
a
size
b
size
#endif
#endif
double
res
0.0
double
res
0.0
for
unsigned
int
i
i
a
size
i
for
int
i
i
a
size
i
res
a
i
b
i
res
a
i
b
i
@@ -48,7 +48,7 @@ vec product(const vec& a, const vec& b)
#endif
#endif
vec
res
a
size
vec
res
a
size
for
unsigned
int
i
i
a
size
i
for
int
i
i
a
size
i
res
i
a
i
b
i
res
i
a
i
b
i
02008951
@@ -256,13 +256,26 @@ template<typename T> T clamp(T x, T a, T b)
return
std
max
T
std
min
T
x
b
a
return
std
max
T
std
min
T
x
b
a
#ifdef WIN32
#define NOT_IMPLEMENTED() \
std::cerr << "<<ERROR>> not implemented " << __FUNCDNAME__ << " in file " << __FILE__ \
<< ":" << __LINE__ << std::endl; \
throw
#else
std::cerr << "<<ERROR>> not implemented " << __PRETTY_FUNCTION__ << " in file " << __FILE__ \
throw
throw
#endif
// Mathematical definition not provided on the Window plateform
#ifdef WIN32
#ifdef WIN32
#define M_PI 3.14159265
template
typename
T
bool
isnan
T
x
return
x
std
numeric_limits
T
signaling_NaN
#endif
#endif
#ifdef WIN32
#ifdef WIN32
02008951
@@ -10,7 +10,7 @@ void function::save(const std::string& filename, const arguments& args) const
bool
is_matlab
args
"export"
"matlab"
bool
is_matlab
args
"export"
"matlab"
// Open the file
// Open the file
std
ofstream
file
filename
std
ofstream
file
filename
c_str
if
file
is_open
if
file
is_open
std
cerr
"<<ERROR>> unable to open output file for writing"
std
endl
std
cerr
std
endl
02008951
@@ -261,7 +261,7 @@ vec rational_function_1d::value(const vec& x) const
std
ostream
operator
std
ostream
out
const
r
std
ostream
operator
std
ostream
out
const
r
std
cout
"p = ["
std
cout
"p = ["
for
unsigned
int
i
i
r
a
size
i
for
int
i
i
r
a
size
i
if
i
if
i
@@ -272,7 +272,7 @@ std::ostream& operator<< (std::ostream& out, const rational_function_1d& r)
std
cout
std
endl
std
cout
std
endl
std
cout
"q = ["
std
cout
"q = ["
for
unsigned
int
i
i
r
b
size
i
for
int
i
i
r
b
size
i
if
i
if
i
02008951
@@ -57,8 +57,8 @@ void vertical_segment::load(const std::string& filename, const arguments& args)
_min
resize
dimX
_min
resize
dimX
_max
resize
dimX
_max
resize
dimX
min
args
get_vec
"min"
_nX
std
numeric_limits
double
max
min
args
get_vec
"min"
_nX
std
numeric_limits
float
max
max
args
get_vec
"max"
_nX
std
numeric_limits
double
max
max
args
get_vec
"max"
_nX
std
numeric_limits
float
max
for
int
k
k
dimX
k
for
int
k
k
dimX
k
@@ -121,7 +121,7 @@ void vertical_segment::load(const std::string& filename, const arguments& args)
else
else
double
dt
args
get_float
"dt"
0.1
double
dt
args
get_float
"dt"
0.1
f
min_dt
dt
min_dt
dt
max_dt
dt
max_dt
dt
