Commit 0100a576 authored by Laurent Belcour's avatar Laurent Belcour
[CMake] Adding CERES and NLOPT tests
parent 484597b9
...@@ -177,7 +177,9 @@ target_link_libraries(rational_fitter_parallel quadprog) ...@@ -177,7 +177,9 @@ target_link_libraries(rational_fitter_parallel quadprog)
# TODO: Add check before compiling CERES, NLOPT and IPOPT # TODO: Add check before compiling CERES, NLOPT and IPOPT
alta_add_plugin(nonlinear_fitter_ceres nonlinear_fitter_ceres/fitter.cpp) alta_add_plugin(nonlinear_fitter_ceres nonlinear_fitter_ceres/fitter.cpp)
target_link_libraries(nonlinear_fitter_ceres ceres)
alta_add_plugin(nonlinear_fitter_nlopt nonlinear_fitter_nlopt/fitter.cpp) alta_add_plugin(nonlinear_fitter_nlopt nonlinear_fitter_nlopt/fitter.cpp)
target_link_libraries(nonlinear_fitter_nlopt nlopt)
#alta_add_plugin(nonlinear_fitter_ipopt nonlinear_fitter_ipopt/fitter.cpp) #alta_add_plugin(nonlinear_fitter_ipopt nonlinear_fitter_ipopt/fitter.cpp)
# Python bindings # Python bindings
...@@ -279,7 +281,20 @@ if(gold-metallic-paint_FOUND) ...@@ -279,7 +281,20 @@ if(gold-metallic-paint_FOUND)
"--in-data" "data_merl" "--in-data" "data_merl"
"--out-data" "data_brdf_slice" "--out-data" "data_brdf_slice"
WORKING_DIRECTORY "${CMAKE_BINARY_DIR}/tests") WORKING_DIRECTORY "${CMAKE_BINARY_DIR}/tests")
foreach(fitter IN ITEMS eigen ceres nlopt)
add_test(NAME "data2dbrdf_gold_${fitter}"
COMMAND "data2brdf" "--input" "gold-metallic-paint.exr"
"--output" "gold-metallic-paint-${fitter}.func"
"--data" "data_brdf_slice"
"--fitter" "nonlinear_fitter_${fitter}"
"--func" "[nonlinear_function_diffuse, nonlinear_function_blinn]"
set_tests_properties("data2dbrdf_gold_${fitter}"
PROPERTIES ENVIRONMENT "ALTA_PLUGIN_PATH=${CMAKE_BINARY_DIR}/plugins")
endforeach()
set_tests_properties("data2data_gold" "data2data_gold_slice" set_tests_properties("data2data_gold" "data2data_gold_slice"
PROPERTIES ENVIRONMENT "ALTA_PLUGIN_PATH=${CMAKE_BINARY_DIR}/plugins") PROPERTIES ENVIRONMENT "ALTA_PLUGIN_PATH=${CMAKE_BINARY_DIR}/plugins")
endif() endif()
