Commit e05a61d3 authored by BAIRE Anthony's avatar BAIRE Anthony
initial docker setup
parents
.*.sw[op]
.stamp.*
.deps.*
PREFIX = allgo/
include docker.mk
ALLGO containers
Overview
A minimal deployment of allgo consists of 4 docker images:
- **allgo/rails**: the rails application server
- **allgo/mysql**: the mysql database server
- **allgo/docker**: the manager for user docker containers
- **allgo/ssh**: the ssh frontend (giving access to the sandboxes)
These images may be deployed multiple times to implement multiple independent
environments (eg: production, qualification, ...).
Additionally there are two images that are meant to be deployed only once (they
may serve multiple environments)
- **allgo/registry**: the docker registry
- **allgo/nginx**: the frontal http server
There is an extra image used only in development:
- **allgo/smtpsink**: a SMTP server that catches and stores all incoming messages into a single mailbox
Each environment has its own docker network. The nginx container is connected
to all these networks to that it can connect to the rails servers.
Conventions
All docker images use the following conventions.
### External volumes
They data is stored in:
- `/vol/rw` for persistent data
- `/vol/ro` for persistent data in read-only access
- `/vol/cache` for cache data (persistent data that may be destroyed at any time without any consequence)
- `/vol/log` for the logs
These paths are expected to be mounted as external volumes, either separately (typical for a production deployment) or with a single mount at `/vol` (typical for a development environment). The owner of external volumes must be the same as the uid used for the app inside the container.
### Admin scripts
Each container may contain a set of scripts for admin purpose (especially for managing the content of external volumes)
- `/dk/container_init` initialise the content of the external volumes (eg: create and seed a database, write a default config, ...)
- `/dk/image_upgrade` apply security upgrades to the image. This command is expected to exit with 0 if successful and to output something on stdout/stderr when something was upgraded an nothing if nothing was upgraded (thus if the output is empty, it is not necessary to commit a new image).
Development environment
The development environment is managed with docker-compose. There are 3 important files:
- `docker-compose.yml` the docker-compose configuration
- `prepare.sh` a shell script which is meant to be sourced in the shell before
working with the environment
- `bootstrap` the bootstrap script
It provides 7 containers:
- `dev-docker`
- `dev-mysql`
- `dev-nginx`
- `dev-rails`
- `dev-registry`
- `dev-smtpsink`
- `dev-ssh`
All external volumes are stored in `/data/dev/` (the path is absolute because
it is tricky to use a relative path with the allgo/docker image).
For convenience, all containers not running as root (rails, mysql, registry)
have their user overridden to the UID:GID of the developer running
docker-compose. This is managed with the `DOCKER_USER` environment variable set
by `prepare.sh`.
For convenience (again), there is an extra external volumes for `dev-rails`,
`dev-docker` and `dev-ssh` so that the source directory of the app is mounted
inside `/opt/` (in fact it overrides the actual application files provided by
the docker image). The purpose is to avoid rebuilding a new docker image for
each development iteration.
### Getting started
The sources are located in two repositories:
- *rails-allgo*: the rails application repository
- *allgo*: the deployment repository
To set up the development environment, run:
1. get the sources
<pre>
git clone git@gitlab.irisa.fr:charly.maupetit/rails-allgo.git
git clone git@gitlab.irisa.fr:sebastien.campion/allgo.git
cd allgo
</pre>
**Note:** the *allgo* repository has a symbolic link to the
*rails-allgo* repository. They should be cloned at the same place (or
the link will be broken).
2. *(as root)* create `/data/dev` and make it owned by the developer
<pre>
sudo mkdir -p /data/dev
sudo chown USER: /data/dev
</pre>
3. source the `prepare.sh` script (to be run every time before you start working)
<pre>
. prepare.sh
</pre>
4. bootstrap the environment
<pre>
./bootstrap
</pre>
This command will run the `/dk/init_container` in every container that
needs it, then start the container.
The first run takes a very long time because all images are built from
scratch (especially the rails image which builds ruby source).
You have enough time for a coffee break.
**Note** by default `bootstrap` works on all containers. It is possible
to give an explicit list of containers instead. Example:
<pre>
./bootstrap dev-mysql dev-rails
</pre>
5. for convenience, you may want to alias `docker-compose` as `fig` (because
`fig` is much faster to type than `docker-compose` and you will have to
type it a lot). Somewhere in your `.bashrc` you should add:
<pre>
alias fig=docker-compose
</pre>
### Common commands
The official doc for docker-compose is available at: [https://docs.docker.com/compose/
https://docs.docker.com/compose/]()
- start all containers (in the background)
<pre>
fig up -d
</pre>
- start all containers (in the foreground, i.e interactively, when you hit Ctrl-C all containers are stop)
<pre>
fig up -d
</pre>
- soft cleanup (stop and remove all containers)
<pre>
fig down
</pre>
- hard cleanup (remove images too)
<pre>
fig down --rmi local
</pre>
- restart a container
<pre>
fig restart dev-rails
</pre>
- restart a container using a new docker image (if the image has been rebuilt since the last start)
<pre>
fig up dev-rails
</pre>
- rebuild an image
<pre>
fig build dev-railf
</pre>
- **Note:** most commands work on every container by default (eg: up down
start stop restart ...) they can be use on an individual container too:
<pre>
fig restart dev-docker dev-rails
</pre>
- run a container with an arbitrary command (eg: to have access to the rails console)
<pre>
fig run dev-rails bash
</pre>
**Note:** containers created by `fig run` have the same parameters as
the referenced containers but their name is different (eg:
*allgo_dev-ssh_run_1*), which means that this container is not
reachable by the others (this may be an issue for example if you want
to run the mysqld server manually: `fig run dev-mysql mysqld` -> this
container won't be reachable by the ssh and rails containers)
- follow the output of all containers:
<pre>
fig logs --tail=1 --follow
</pre>
Production environment
- TODO unicorn/nginx integration
- TODO use capistrano too ?
Images design
## registry
Hosts docker registry with a nginx configured as a reverse proxy. It listens to 4 ports:
- :8000 (*production*) access limited to `/v2/allgo/prod/`
- :8001 (*qualification*) access limited to `/v2/allgo/qualif/`
- :8002 (*development*) access limited to `/v2/allgo/dev`
- :5000 (*legacy production*) access limited to `/v2/allgo`(which is mapped to `/v2/allgo/prod/`)
## mysql
Hosts a mysql server listening on port 3306 with two databases: `allgo` and
`allgo_test` and two users: `allgo` and `ssh`.
- `allgo` has read/write access to both databases
- `ssh` has read only access to `allgo`
## rails
Hosts three daemons for running allgo:
- the rails server
- the sidekiq queue manager
- the redis db server
(TODO add unicorn+nginx for production)
## ssh
Hosts the ssh front server for accessing the sandboxes (`ssh
WEBAPP@sid.allgo.irisa.fr`). Each allgo webapp is mapped to a system user
(using Glibc NSS) starting at uid 2000.
- `/etc/passwd` and `/etc/group` are overriden so as to contain only the two users (*root* and *sshd*) and one group (*nogroup*) required to run the ssh server
- Extra users are obtained from the mysql database (using libnss-mysql-bg) and mapped as follows:
<pre>
name = webapps.docker_name
uid = webapps.id
gid = 65534 (nogroup)
gecos = webapps.name
shell = /bin/allgo-shell
</pre>
- The ssh server is configured to accept key-based authentication only. The
list of public keys is obtained from the (using an AuthorizedKeysCommand).
- The forced shell (`allgo-shell`) connects to the webapp sandbox (if running).
- The connection to the sandbox is made though a unix socket and a set of pipes
in the filesystem.
## docker
Hosts the *docker-allgo-proxy* which manages all docker operations (run, stop,
rm, commit, pull, push, ...) on behalf of the rails container.
Technically speaking this container had root privileges since it has access to
the docker socket.
The proxy script enforces restrictions (according to the current environment: eg prod/qualif/dev) on:
- the registry (for pulling/pushing)
- the paths of external volumes
- the container names (*ENV*-user-*XXXX*)
## nginx
Hosts the frontal nginx server, its purpose is to:
- give access to one or more allgo instances
- manage TLS encryption
## smtpsink
Hosts a SMTP server (port 25) and an IMAP server (port 143) for
development/qualification
Its purpose is to channel all outgoing mail (received on port 25) into a single
mailbox.
The mailbox is accessible with IMAP as user *sink* (password *sink*).
Dockerfile*
.git
.*.swo
.*.swp
FROM debian:jessie
ADD apt-getq /usr/local/bin/
RUN sed -i 's/httpredir.debian.org/miroir.irisa.fr/; s/main *$/main contrib non-free/' /etc/apt/sources.list &&\
apt-getq update &&\
apt-getq dist-upgrade &&\
apt-getq install vim-tiny locales patch realpath logrotate python3
ENV LANG en_US.UTF-8
COPY . /tmp/context
RUN ["sh", "/tmp/context/setup.sh"]
#!/bin/sh
set -e
for p in "$@"
do
echo "`basename $p`"
patch -p0 <"$p"
done
#!/bin/sh
export DEBIAN_FRONTEND=noninteractive
exec apt-get -qq -y --no-install-recommends "$@"
#!/bin/bash
ETC="/etc/local-diversions"
print_help()
cmd="`basename $0`"
cat >&2 <<EOF
usage: $cmd show list existing diversions
$cmd add ORIG DEST add a diversion (WARNING: erases ORIG)
$cmd rm ORIG remove a diversion
EOF
exit 1
die()
echo "error: $*" >&2
exit 1
load()
# load the current diversions
if [ -e "$ETC" ] ; then
grep -q "^declare -g -A div=" "$ETC" || die "invalid config file $ETC"
. "$ETC"
else
declare -g -A div=()
fi
save()
declare -p div > "$ETC.tmp"
sed -i "s/^declare/declare -g/" "$ETC.tmp"
mv "$ETC.tmp" "$ETC"
get()
local value="${div["$1"]}"
[ -n "$value" ] || die "unknown key: $1"
echo "$value"
validate_key()
[[ "$1" =~ ^/ ]] || die "path must be absolute: $1"
touch "$1" # create the file in case it does not exist yet
local rp="`realpath "$1"`"
[ "$1" = "$rp" ] || [ "$1" = "$rp/" ] || die "path is not a real path: $1 (resolves to $rp)"
[ "$rp" != "/" ] || die "you should never try to divert /"
echo "$rp"
validate_value()
echo "$1"
enable_diversion()
local key="$1"
local value="`get "$1"`"
rm -rf "$key"
ln -s "$value" "$key"
disable_diversion()
local key="$1"
if [ -L "$key" ] ; then
rm "$key"
else
[ ! -e "$key" ] || die "unable to disable diversion: $key is not a symbolic link"
fi
set -e
load
CMD="$1"
shift
case "$CMD" in
show)
[ $# = 0 ] || print_help
printf "%-32s %s\n" "PATH" "DIVERTED TO"
for k in ${!div[@]}
do
printf "%-32s %s\n" "$k" "${div["$k"]}"
done
add)
[ $# = 2 ] || print_help
KEY="`validate_key "$1"`"
VALUE="`validate_value "$2"`"
previous="${div[$KEY]}"
[ -z "$previous" ] || die "$KEY is already diverted to $previous"
div["$KEY"]="$VALUE"
enable_diversion "$KEY"
save
rm)
[ $# = 1 ] || print_help
KEY="$1"
VALUE="`get "$KEY"`"
unset div["$KEY"]
disable_diversion "$KEY"
save
enable|disable)
for k in ${!div[@]}
do
"$CMD"_diversion "$k"
done
print_help
esac
#!/bin/sh
set -e
STATEFILE="/vol/log/.logrotate.status"
for CANDIDATE in /vol/ro/logrotate.d /dk/logrotate.d
do
if [ -d "$CANDIDATE" ]
then
TMPFILE="`tempfile`"
cat > "$TMPFILE" <<EOF
# see "man logrotate" for details
# rotate log files weekly
weekly
# keep 4 weeks worth of backlogs
rotate 4
# create new (empty) log files after rotating old ones
create
# uncomment this if you want your log files compressed
#compress
# packages drop log rotation information into this directory
include $CANDIDATE
EOF
logrotate "$TMPFILE" -s "$STATEFILE"
rm "$TMPFILE"
exit 0
fi
done
#!/bin/sh
# container upgrade script
# The output must be empty when no upgrade is needed.
set -e
diversions disable
apt-getq update
apt-getq upgrade -u
# restore our symbolic links in case they are overwritten by a package
diversions enable
#!/usr/bin/python3
import atexit, collections, os, subprocess, sys, traceback
def die(fmt, *k):
sys.stderr.write("error:%s\n" % (fmt % k))
sys.exit(1)
class Failure(Exception):
pass
class migration:
__instances = collections.defaultdict(lambda: {})
def __init__(self, previous, next):
self.previous = previous
self.next = next
self.func = None
assert next not in self.__instances[previous], ("duplicated migration: %s -> %s" % key)
self.__instances[previous][next] = self
def __call__(self, func):
assert self.func is None, "migration function already set"
self.func = func
def __str__(self):
return "migration %r -> %r" % (self.previous, self.next)
@classmethod
def run(cls, from_version, to_version):
# find the shortest migration path for each version
# version -> (migration, ...)
routes = {from_version: ()}
queue = collections.deque([from_version])
while queue:
version = queue.popleft()
for migration in cls.__instances[version].values():
assert migration.previous == version
if migration.next not in routes:
routes[migration.next] = routes[migration.previous] + (migration,)
queue.append(migration.next)
else:
assert len(routes[migration.next]) <= len(routes[migration.previous]) + 1
fmt_route = lambda r: from_version + "".join(" -> %s" % m.next for m in r)
if routes:
print ("possible migrations from version %s" % from_version)
for version in sorted(routes):
print(" %-8s %s" % (version, fmt_route(routes[version])))
print()
route = routes.get(to_version)
if not route:
die("no migration path from version %s to %s", from_version, to_version)
print("migration path: %s" % fmt_route(route))
for migration in route:
print("\n"
"┏━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━┓\n"
"┃ applying %-33s ┃\n"
"┗━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━┛" % migration)
try:
# flush stdout/stderr because we may have some interleaving
sys.stdout.flush()
sys.stderr.flush()
migration.func()
except subprocess.CalledProcessError as e:
sys.stderr.write("error: %s\n" % e)
die("migration %s failed", migration)
except SystemExit as e:
if e.code:
except Exception as e:
traceback.print_exc()
die("unexpected error in migration %s", migration)
def run():
atexit.unregister(_guard)
if len(sys.argv) != 3:
die("usage: %s SRC_VERSION DST_VERSION", sys.argv[0])
migration.run(*sys.argv[1:3])
@atexit.register
def _guard():
die("dk.migration.run() was not called")
# set the minimum uid/gid for adduser/useradd/groupadd to 500
# so as not to overlap with host users and groups
--- etc/login.defs
+++ etc/login.defs
@@ -159,7 +159,7 @@
# Min/max values for automatic uid selection in useradd
-UID_MIN 1000
+UID_MIN 500
UID_MAX 60000
# System accounts
#SYS_UID_MIN 100
@@ -168,7 +168,7 @@
# Min/max values for automatic gid selection in groupadd
-GID_MIN 1000
+GID_MIN 500
GID_MAX 60000
# System accounts
#SYS_GID_MIN 100
#!/bin/sh
set -x -e
cat >/etc/locale.gen <<EOF
en_US.UTF-8 UTF-8
fr_FR.UTF-8 UTF-8
EOF
locale-gen
cd /tmp/context
cp -r dk /dk
mkdir /usr/lib/python3/dist-packages/dk/
cp dk_migration.py /usr/lib/python3/dist-packages/dk/migration.py
install -m 0755 apply-patches /usr/local/bin
install -m 0755 diversions /usr/local/sbin
cd /
apply-patches /tmp/context/patches/*.diff
rm -rf /tmp/context
#!/bin/bash
set -e
old_du="$DOCKER_USER"
. prepare.sh
# build base image (if not present)
if ! docker inspect --type image allgo/base-debian > /dev/null
then
(set -x ; docker build -t allgo/base-debian base-debian)
fi
if [ -n "$*" ] ; then
TODO="$*"
else
docker-compose down
TODO="dev-mysql dev-smtpsink dev-ssh dev-rails dev-nginx"
fi
(set -xe
for name in $TODO
do
# ensure $name does not start with '-'
[[ ! "$name" =~ ^- ]]
# FIXME: race condition in docker-compose (if the command
# finishes too quickly, then it is run twice)
docker-compose run --rm "$name" sh -c "sleep 1 ; /dk/container_init"
done
docker-compose up -d
docker-compose ps
if [ -z "$old_du" ]
then
echo 'NOTE: the env variable DOCKER_USER is not set. You should run ". prepare.sh" before working'
fi
/data/dev
\ No newline at end of file
# vim:sts=4:sw=4:et:
dev-registry:
container_name: dev-registry
build: registry
#image: allgo/registry
user: "$DOCKER_USER"
ports:
- "127.0.0.1:8000-8002:8000-8002"
