Commit f1307861 authored by BAIRE Anthony's avatar BAIRE Anthony
fix the name of the 'controller' container
(which was previously named 'docker')
parent c46fb805
......@@ -325,9 +325,9 @@ WEBAPP@sid.allgo.irisa.fr`). Each allgo webapp is mapped to a system user
- The connection to the sandbox is made though a unix socket and a set of pipes
in the filesystem.
## docker
## controller
Hosts the *docker-allgo-proxy* which manages all docker operations (run, stop,
Hosts the *docker-controller* which manages all docker operations (run, stop,
rm, commit, pull, push, ...) on behalf of the django container.
Technically speaking this container had root privileges since it has access to
