Commit ef1de3f1 authored by BAIRE Anthony's avatar BAIRE Anthony
typos
parent a192f26e
...@@ -84,7 +84,7 @@ docker-compose. This is managed with the `DOCKERUSER` environment variable set ...@@ -84,7 +84,7 @@ docker-compose. This is managed with the `DOCKERUSER` environment variable set
[in the `.env` file](https://docs.docker.com/compose/environment-variables/#the-env-file) by [in the `.env` file](https://docs.docker.com/compose/environment-variables/#the-env-file) by
`prepare.sh`. `prepare.sh`.
For convenience (again), there is an extra external volumes for `dev-django`, For convenience (again), there is an extra external volume for `dev-django`,
`dev-controller` and `dev-ssh` so that the source directory of the app is mounted `dev-controller` and `dev-ssh` so that the source directory of the app is mounted
inside `/opt/` (in fact it overrides the actual application files provided by inside `/opt/` (in fact it overrides the actual application files provided by
the docker image). The purpose is to avoid rebuilding a new docker image for the docker image). The purpose is to avoid rebuilding a new docker image for
...@@ -336,7 +336,7 @@ WEBAPP@sid.allgo.irisa.fr`). Each allgo webapp is mapped to a system user ...@@ -336,7 +336,7 @@ WEBAPP@sid.allgo.irisa.fr`). Each allgo webapp is mapped to a system user
Hosts the *docker-controller* which manages all docker operations (run, stop, Hosts the *docker-controller* which manages all docker operations (run, stop,
rm, commit, pull, push, ...) on behalf of the django container. rm, commit, pull, push, ...) on behalf of the django container.
Technically speaking this container had root privileges since it has access to Technically speaking this container has root privileges since it has access to
the docker socket. the docker socket.
The proxy script enforces restrictions (according to the current environment: eg prod/qualif/dev) on: The proxy script enforces restrictions (according to the current environment: eg prod/qualif/dev) on:
Supports Markdown
