Commit ad2640c3 authored by BAIRE Anthony's avatar BAIRE Anthony
reduce the default memory requirements for new apps
parent 920eff96
Pipeline #202725 failed with stages
in 1 second
...@@ -192,7 +192,7 @@ with env_loader.EnvironmentVarLoader(__name__, "ALLGO_", ...@@ -192,7 +192,7 @@ with env_loader.EnvironmentVarLoader(__name__, "ALLGO_",
default="localhost", default="localhost",
help="allowed domains to create applications") help="allowed domains to create applications")
env_var("ALLGO_WEBAPP_DEFAULT_MEMORY_LIMIT_MB", default=str(4*1024), env_var("ALLGO_WEBAPP_DEFAULT_MEMORY_LIMIT_MB", default=str(1024),
help="default memory limit (in megabytes) for newly created webapps") help="default memory limit (in megabytes) for newly created webapps")
env_var("ALLGO_IMPORT_URL", default="https://allgo.inria.fr", env_var("ALLGO_IMPORT_URL", default="https://allgo.inria.fr",
