Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit a1bf56d4 authored by BAIRE Anthony's avatar BAIRE Anthony
Merge branch 'ui-suggestions' into 'django'
UI : two suggestions for the user
See merge request !153
parents b927a987 04827ac2
Pipeline #56500 failed with stage
in 1 minute and 9 seconds
...@@ -429,9 +429,9 @@ class WebappImport(ProviderAccessMixin, SuccessMessageMixin, FormView): ...@@ -429,9 +429,9 @@ class WebappImport(ProviderAccessMixin, SuccessMessageMixin, FormView):
# ensure this app has the same owner # ensure this app has the same owner
if email_addr is None: if email_addr is None:
return error("""this webapp belongs to another user (if you think return error("""this webapp belongs to another user (different
it really belongs to you, then you should contact the e-mail address). If this other e-mail address belongs to you,
administrators)""") then you should add it to your profile.""")
# ensure the user email is verified # ensure the user email is verified
if not email_addr.verified: if not email_addr.verified:
...@@ -159,7 +159,7 @@ ...@@ -159,7 +159,7 @@
{% else %} {% else %}
<p class="mt-3">In order to run a job you need to by <a href="{% url 'account_login' %}" title="Sign in on A||Go">identified</a> <p class="mt-3">In order to run a job you need to be <a href="{% url 'account_login' %}" title="Sign in on A||Go">identified</a>
or <a href="{% url 'account_signup' %}" title="Sign up on A||Go">register a new account</a>.</p> or <a href="{% url 'account_signup' %}" title="Sign up on A||Go">register a new account</a>.</p>
{% endif %} {% endif %}
</div> </div>
...@@ -76,7 +76,13 @@ ...@@ -76,7 +76,13 @@
the command below or click to the Docker panel if you prefer to use this method the command below or click to the Docker panel if you prefer to use this method
or are using continuous development. or are using continuous development.
<h5>1. Connect to SSH</h5> <h5>1. Connect via SSH</h5>
{% if not user.allgouser.sshkey %}
<p><span class="text-danger"><i class="fas fa-exclamation-circle text-danger"></i> important:</span>
you must <a href="{% url 'main:user_ssh_add' %}">add your public SSH key</a> to your account before using this command
</p>
{% endif %}
<pre class="language-bash mb-3"><code class="language-*">{{ ssh_command }}</code></pre> <pre class="language-bash mb-3"><code class="language-*">{{ ssh_command }}</code></pre>
