GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
allgo
allgo
a1bf56d4
a1bf56d4
BAIRE Anthony
Merge branch 'ui-suggestions' into 'django'
UI : two suggestions for the user See merge request
!153
parents
b927a987
04827ac2
Pipeline
#56500
failed with stage
in 1 minute and 9 seconds
3
django/allgo/main/views.py
a1bf56d4
@@ -429,9 +429,9 @@ class WebappImport(ProviderAccessMixin, SuccessMessageMixin, FormView):
# ensure this app has the same owner
if
email_addr
is
None
return
error
"""this webapp belongs to another user (if
you think
it really belongs to you, then you should contact the
administrators)
return
error
d
if
ferent
e-mail address). If this other e-mail address belongs to you,
then you should add it to your profile.
# ensure the user email is verified
if
not
email_addr
verified
django/allgo/templates/webapp_detail.html
a1bf56d4
@@ -159,7 +159,7 @@
{% else %}
<p
class=
"mt-3"
In order to run a job you need to b
y
<a
href=
"{% url 'account_login' %}"
title=
"Sign in on A||Go"
identified
</a>
<p
class=
"mt-3"
e
<a
href=
title=
"Sign in on A||Go"
identified
</a>
<a
href=
"{% url 'account_signup' %}"
title=
"Sign up on A||Go"
register a new account
</a>
</p>
{% endif %}
</div>
django/allgo/templates/webapp_sandbox_panel.html
a1bf56d4
@@ -76,7 +76,13 @@
the command below or click to the Docker panel if you prefer to use this method
or are using continuous development.
<h5>
1. Connect to SSH
</h5>
<h5>
1. Connect via SSH
</h5>
{% if not user.allgouser.sshkey %}
<p><span
class=
"text-danger"
><i
class=
"fas fa-exclamation-circle text-danger"
></i>
important:
</span>
you must
<a
href=
"{% url 'main:user_ssh_add' %}"
add your public SSH key
</a>
to your account before using this command
</p>
{% endif %}
<pre
class=
"language-bash mb-3"
><code
class=
"language-*"
{{ ssh_command }}
</code></pre>
