GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
allgo
allgo
30ba31c8
30ba31c8
BAIRE Anthony
doc
fab73f7e
docker/controller.py
30ba31c8
@@ -295,11 +295,18 @@ class Manager:
return
yield
from
asyncio
get_event_loop
run_in_executor
self
_executor
k
return
yield
from
asyncio
get_event_loop
run_in_executor
self
_executor
k
# notes:
# - does not need to be reentrant
# - will be called a second time in a row if .process() is called during
# the execution of ._process()
def
_process
self
key
reset
def
_process
self
key
reset
"""Actual implementation of the job (to be reimplemented in inherited classes)
The Manager class guarantees that this function cannot be called
multiple times concurrently on the same key (in case the same key is
submitted multiple times, they Manager will call this function a second
time after it has terminated).
`reset` is a function that may be called to reset the 'dirty' state of
this key (this is to avoid calling ._process() a second time if not
necessary)
raise
NotImplementedError
raise
NotImplementedError
asyncio
coroutine
asyncio
coroutine
