Support
Chameleon
Project overview
Project overview
Boards
AGULLO Emmanuel
Chameleon
ba45baf5
ba45baf5
PRUVOST Florent
add an option to force looking for parallel kernels -> Intel MKL multithreaded
a0696a6b
9 additions
+9
CMakeLists.txt
CMakeLists.txt
+9
CMakeLists.txt
ba45baf5
@@ -243,6 +243,10 @@ if(CHAMELEON_SCHED_STARPU)
endif
CHAMELEON_ENABLE_PRUNING_STATS
endif
endif
endif
# Option for parallel kernels
option
CHAMELEON_KERNELS_PAR
"Enable parallel kernels (requires Intel MKL)"
OFF
# Initially we need to generate files for different precisions
# TODO: use this option to avoid generate multiple precisions each time we launch cmake
#option(CHAMELEON_GEN_PREC "Generate source files precisions" ON)
@@ -253,6 +257,11 @@ if (CMAKE_C_COMPILER_ID MATCHES "Intel" AND (NOT BLA_VENDOR OR BLA_VENDOR STREQU
set
BLA_VENDOR
"Intel10_64lp_seq"
set
BLA_VENDOR
"Intel10_64lp_seq"
endif
endif
# If parallel kernels ON we need the parallel MKL version
if
set
BLA_VENDOR
"Intel10_64lp"
endif
# Build dependency HQR library #
