Commit 896615d9 authored by PRUVOST Florent's avatar PRUVOST Florent
avoid to use operator as a variable because it is cxx reserved keyword (API problem)
parent a4a509da
...@@ -56,11 +56,11 @@ ...@@ -56,11 +56,11 @@
int CHAMELEON_map_Tile( cham_uplo_t uplo, int CHAMELEON_map_Tile( cham_uplo_t uplo,
CHAM_desc_t *A, CHAM_desc_t *A,
cham_unary_operator_t operator, cham_unary_operator_t op_fct,
void *op_args ); void *op_args );
int CHAMELEON_map_Tile_Async( cham_uplo_t uplo, int CHAMELEON_map_Tile_Async( cham_uplo_t uplo,
void *op_args, void *op_args,
RUNTIME_sequence_t *sequence, RUNTIME_sequence_t *sequence,
RUNTIME_request_t *request ); RUNTIME_request_t *request );
...@@ -97,7 +97,7 @@ typedef int (*cham_unary_operator_t)( const CHAM_desc_t *desc, ...@@ -97,7 +97,7 @@ typedef int (*cham_unary_operator_t)( const CHAM_desc_t *desc,
void INSERT_TASK_map( const RUNTIME_option_t *options, void INSERT_TASK_map( const RUNTIME_option_t *options,
cham_uplo_t uplo, const CHAM_desc_t *A, int Am, int An, cham_uplo_t uplo, const CHAM_desc_t *A, int Am, int An,
cham_unary_operator_t operator, void *op_args ); cham_unary_operator_t op_fct, void *op_args );
#include "chameleon/tasks_z.h" #include "chameleon/tasks_z.h"
#include "chameleon/tasks_d.h" #include "chameleon/tasks_d.h"
