Commit 5ee2abef authored by Mathieu Faverge's avatar Mathieu Faverge
RIP morse
parent 165fe037
...@@ -57,9 +57,9 @@ set(CHAMELEON_CONTROL ...@@ -57,9 +57,9 @@ set(CHAMELEON_CONTROL
../control/descriptor.c ../control/descriptor.c
../control/workspace.c ../control/workspace.c
../control/tile.c ../control/tile.c
../control/morse_f77.c ../control/chameleon_f77.c
../control/morse_mf77.c ../control/chameleon_mf77.c
# ../control/morsewinthread.c # ../control/chameleonwinthread.c
set(flags_to_add "") set(flags_to_add "")
...@@ -68,7 +68,7 @@ foreach(_prec ${CHAMELEON_PRECISION}) ...@@ -68,7 +68,7 @@ foreach(_prec ${CHAMELEON_PRECISION})
endforeach() endforeach()
set_source_files_properties(../control/tile.c PROPERTIES COMPILE_FLAGS "${flags_to_add}") set_source_files_properties(../control/tile.c PROPERTIES COMPILE_FLAGS "${flags_to_add}")
# Generate the morse sources for all possible precisions # Generate the chameleon sources for all possible precisions
set(CHAMELEON_SRCS_GENERATED "") set(CHAMELEON_SRCS_GENERATED "")
set(ZSRC set(ZSRC
...@@ -251,7 +251,7 @@ precisions_rules_py(CHAMELEON_SRCS_GENERATED "${ZSRC}" ...@@ -251,7 +251,7 @@ precisions_rules_py(CHAMELEON_SRCS_GENERATED "${ZSRC}"
set(CONTROL_SRCS_GENERATED "") set(CONTROL_SRCS_GENERATED "")
set(ZSRC set(ZSRC
../control/workspace_z.c ../control/workspace_z.c
../control/morse_zf77.c ../control/chameleon_zf77.c
precisions_rules_py(CONTROL_SRCS_GENERATED "${ZSRC}" precisions_rules_py(CONTROL_SRCS_GENERATED "${ZSRC}"
...@@ -264,21 +264,21 @@ set(CHAMELEON_SRCS ...@@ -264,21 +264,21 @@ set(CHAMELEON_SRCS
${CONTROL_SRCS_GENERATED} ${CONTROL_SRCS_GENERATED}
# Generate the morse fortran sources for all possible precisions # Generate the chameleon fortran sources for all possible precisions
if(HAVE_ISO_C_BINDING) if(HAVE_ISO_C_BINDING)
set(CHAMELEON_SRCS_F_GENERATED "") set(CHAMELEON_SRCS_F_GENERATED "")
set(ZSRCF set(ZSRCF
../control/morse_zcf90.F90 ../control/chameleon_zcf90.F90
../control/morse_zf90.F90 ../control/chameleon_zf90.F90
../control/morse_zf90_wrappers.F90 ../control/chameleon_zf90_wrappers.F90
precisions_rules_py(CHAMELEON_SRCS_F_GENERATED "${ZSRCF}" precisions_rules_py(CHAMELEON_SRCS_F_GENERATED "${ZSRCF}"
PRECISIONS "${CHAMELEON_PRECISION}" PRECISIONS "${CHAMELEON_PRECISION}"
TARGETDIR "control" ) TARGETDIR "control" )
set(CHAMELEON_SRCSF set(CHAMELEON_SRCSF
../control/morse_f90.f90 ../control/chameleon_f90.f90
${CHAMELEON_SRCS_F_GENERATED} ${CHAMELEON_SRCS_F_GENERATED}
endif(HAVE_ISO_C_BINDING) endif(HAVE_ISO_C_BINDING)
...@@ -53,19 +53,19 @@ ...@@ -53,19 +53,19 @@
* Identifies this function call (for exception handling purposes). * Identifies this function call (for exception handling purposes).
void morse_pzbuild( cham_uplo_t uplo, CHAM_desc_t *A, void *user_data, void* user_build_callback, void chameleon_pzbuild( cham_uplo_t uplo, CHAM_desc_t *A, void *user_data, void* user_build_callback,
RUNTIME_sequence_t *sequence, RUNTIME_request_t *request ) RUNTIME_sequence_t *sequence, RUNTIME_request_t *request )
CHAM_context_t *morse; CHAM_context_t *chamctxt;
RUNTIME_option_t options; RUNTIME_option_t options;
int m, n; int m, n;
int ldam; int ldam;
morse = morse_context_self(); chamctxt = chameleon_context_self();
if (sequence->status != CHAMELEON_SUCCESS) if (sequence->status != CHAMELEON_SUCCESS)
return; return;
RUNTIME_options_init(&options, morse, sequence, request); RUNTIME_options_init(&options, chamctxt, sequence, request);
for (m = 0; m < A->mt; m++) { for (m = 0; m < A->mt; m++) {
ldam = BLKLDD(A, m); ldam = BLKLDD(A, m);
...@@ -81,5 +81,5 @@ void morse_pzbuild( cham_uplo_t uplo, CHAM_desc_t *A, void *user_data, void* use ...@@ -81,5 +81,5 @@ void morse_pzbuild( cham_uplo_t uplo, CHAM_desc_t *A, void *user_data, void* use
RUNTIME_options_finalize( &options, morse); RUNTIME_options_finalize( &options, chamctxt);
...@@ -20,7 +20,7 @@ ...@@ -20,7 +20,7 @@
#include "control/common.h" #include "control/common.h"
void morse_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, void chameleon_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
RUNTIME_sequence_t *sequence, RUNTIME_request_t *request) RUNTIME_sequence_t *sequence, RUNTIME_request_t *request)
int k; int k;
...@@ -31,34 +31,34 @@ void morse_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, ...@@ -31,34 +31,34 @@ void morse_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
for (k = 0; k < A->nt; k++) { for (k = 0; k < A->nt; k++) {
tempkn = k == A->nt-1 ? A->n-k*A->nb : A->nb; tempkn = k == A->nt-1 ? A->n-k*A->nb : A->nb;
A1 = morse_desc_submatrix(A, k*A->mb, k*A->nb, A->m-k*A->mb, tempkn); A1 = chameleon_desc_submatrix(A, k*A->mb, k*A->nb, A->m-k*A->mb, tempkn);
A2 = morse_desc_submatrix(A, k*A->mb, (k+1)*A->nb, A->m-k*A->mb, A->n-(k+1)*A->nb); A2 = chameleon_desc_submatrix(A, k*A->mb, (k+1)*A->nb, A->m-k*A->mb, A->n-(k+1)*A->nb);
T1 = morse_desc_submatrix(T, k*T->mb, k*T->nb, T->m-k*T->mb, T->nb ); T1 = chameleon_desc_submatrix(T, k*T->mb, k*T->nb, T->m-k*T->mb, T->nb );
if ( D != NULL ) { if ( D != NULL ) {
D1 = morse_desc_submatrix(D, k*D->mb, k*D->nb, D->m-k*D->mb, tempkn); D1 = chameleon_desc_submatrix(D, k*D->mb, k*D->nb, D->m-k*D->mb, tempkn);
morse_pzgeqrf( A1, T1, D1, chameleon_pzgeqrf( A1, T1, D1,
sequence, request); sequence, request);
morse_pzunmqr( ChamLeft, ChamConjTrans, chameleon_pzunmqr( ChamLeft, ChamConjTrans,
A1, A2, T1, D1, A1, A2, T1, D1,
if (k+1 < A->nt){ if (k+1 < A->nt){
tempkm = k == A->mt-1 ? A->m-k*A->mb : A->mb; tempkm = k == A->mt-1 ? A->m-k*A->mb : A->mb;
A1 = morse_desc_submatrix(A, k*A->mb, (k+1)*A->nb, tempkm, A->n-(k+1)*A->nb); A1 = chameleon_desc_submatrix(A, k*A->mb, (k+1)*A->nb, tempkm, A->n-(k+1)*A->nb);
A2 = morse_desc_submatrix(A, (k+1)*A->mb, (k+1)*A->nb, A->m-(k+1)*A->mb, A->n-(k+1)*A->nb); A2 = chameleon_desc_submatrix(A, (k+1)*A->mb, (k+1)*A->nb, A->m-(k+1)*A->mb, A->n-(k+1)*A->nb);
T1 = morse_desc_submatrix(T, k*T->mb, (k+1)*T->nb, T->mb, T->n-(k+1)*T->nb); T1 = chameleon_desc_submatrix(T, k*T->mb, (k+1)*T->nb, T->mb, T->n-(k+1)*T->nb);
D1 = morse_desc_submatrix(D, k*D->mb, (k+1)*D->nb, tempkm, D->n-(k+1)*D->nb); D1 = chameleon_desc_submatrix(D, k*D->mb, (k+1)*D->nb, tempkm, D->n-(k+1)*D->nb);
morse_pzgelqf( A1, T1, D1, chameleon_pzgelqf( A1, T1, D1,
morse_pzunmlq( ChamRight, ChamConjTrans, chameleon_pzunmlq( ChamRight, ChamConjTrans,
...@@ -68,33 +68,33 @@ void morse_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, ...@@ -68,33 +68,33 @@ void morse_pzgebrd_ge2gb(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
for (k = 0; k < A->mt; k++) { for (k = 0; k < A->mt; k++) {
A1 = morse_desc_submatrix(A, k*A->mb, k*A->nb, tempkm, A->n-k*A->nb); A1 = chameleon_desc_submatrix(A, k*A->mb, k*A->nb, tempkm, A->n-k*A->nb);
A2 = morse_desc_submatrix(A, (k+1)*A->mb, k*A->nb, A->m-(k+1)*A->mb, A->n-k*A->nb); A2 = chameleon_desc_submatrix(A, (k+1)*A->mb, k*A->nb, A->m-(k+1)*A->mb, A->n-k*A->nb);
T1 = morse_desc_submatrix(T, k*T->mb, k*T->nb, T->mb, T->n-k*T->nb); T1 = chameleon_desc_submatrix(T, k*T->mb, k*T->nb, T->mb, T->n-k*T->nb);
D1 = morse_desc_submatrix(D, k*D->mb, k*D->nb, tempkm, D->n-k*D->nb); D1 = chameleon_desc_submatrix(D, k*D->mb, k*D->nb, tempkm, D->n-k*D->nb);
if (k+1 < A->mt){ if (k+1 < A->mt){
A1 = morse_desc_submatrix(A, (k+1)*A->mb, k*A->nb, A->m-(k+1)*A->mb, tempkn); A1 = chameleon_desc_submatrix(A, (k+1)*A->mb, k*A->nb, A->m-(k+1)*A->mb, tempkn);
T1 = morse_desc_submatrix(T, (k+1)*T->mb, k*T->nb, T->m-(k+1)*T->mb, T->nb ); T1 = chameleon_desc_submatrix(T, (k+1)*T->mb, k*T->nb, T->m-(k+1)*T->mb, T->nb );
D1 = morse_desc_submatrix(D, (k+1)*D->mb, k*D->nb, D->m-(k+1)*D->mb, tempkn); D1 = chameleon_desc_submatrix(D, (k+1)*D->mb, k*D->nb, D->m-(k+1)*D->mb, tempkn);
...@@ -36,10 +36,10 @@ ...@@ -36,10 +36,10 @@
* Parallel tile LQ factorization - dynamic scheduling * Parallel tile LQ factorization - dynamic scheduling
void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, void chameleon_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
size_t ws_worker = 0; size_t ws_worker = 0;
size_t ws_host = 0; size_t ws_host = 0;
...@@ -49,10 +49,10 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, ...@@ -49,10 +49,10 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
int tempkm, tempkn, tempmm, tempnn; int tempkm, tempkn, tempmm, tempnn;
int ib, minMNT; int ib, minMNT;
return; return;
ib = CHAMELEON_IB; ib = CHAMELEON_IB;
...@@ -90,7 +90,7 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, ...@@ -90,7 +90,7 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
RUNTIME_options_ws_alloc( &options, ws_worker, ws_host ); RUNTIME_options_ws_alloc( &options, ws_worker, ws_host );
for (k = 0; k < minMNT; k++) { for (k = 0; k < minMNT; k++) {
RUNTIME_iteration_push(morse, k); RUNTIME_iteration_push(chamctxt, k);
...@@ -169,10 +169,10 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, ...@@ -169,10 +169,10 @@ void morse_pzgelqf(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D,
A->get_rankof( A, m, k ) ); A->get_rankof( A, m, k ) );
RUNTIME_iteration_pop(morse); RUNTIME_iteration_pop(chamctxt);
RUNTIME_options_ws_free(&options); RUNTIME_options_ws_free(&options);
RUNTIME_options_finalize(&options, morse); RUNTIME_options_finalize(&options, chamctxt);
(void)D; (void)D;
...@@ -30,11 +30,11 @@ ...@@ -30,11 +30,11 @@
* Parallel tile LQ factorization (reduction Householder) - dynamic scheduling * Parallel tile LQ factorization (reduction Householder) - dynamic scheduling
void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A, void chameleon_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A,
CHAM_desc_t *TS, CHAM_desc_t *TT, CHAM_desc_t *D, CHAM_desc_t *TS, CHAM_desc_t *TT, CHAM_desc_t *D,
CHAM_desc_t *T; CHAM_desc_t *T;
...@@ -47,10 +47,10 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A, ...@@ -47,10 +47,10 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A,
int ib; int ib;
int *tiles; int *tiles;
return; return;
...@@ -91,7 +91,7 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A, ...@@ -91,7 +91,7 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A,
/* The number of the factorization */ /* The number of the factorization */
for (k = 0; k < K; k++) { for (k = 0; k < K; k++) {
ldak = BLKLDD(A, k); ldak = BLKLDD(A, k);
...@@ -199,10 +199,10 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A, ...@@ -199,10 +199,10 @@ void morse_pzgelqf_param( const libhqr_tree_t *qrtree, CHAM_desc_t *A,
free(tiles); free(tiles);
...@@ -38,10 +38,10 @@ ...@@ -38,10 +38,10 @@
void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS, void chameleon_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS,
...@@ -52,10 +52,10 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS, ...@@ -52,10 +52,10 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS,
int tempkmin, tempkm, tempNn, tempnn, tempmm, tempNRDn; int tempkmin, tempkm, tempNn, tempnn, tempmm, tempNRDn;
int ib; int ib;
return; return;
...@@ -88,7 +88,7 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS, ...@@ -88,7 +88,7 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS,
...@@ -210,10 +210,10 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS, ...@@ -210,10 +210,10 @@ void morse_pzgelqfrh(CHAM_desc_t *A, CHAM_desc_t *T, CHAM_desc_t *D, int BS,
(void)D; (void)D;
...@@ -29,12 +29,12 @@ ...@@ -29,12 +29,12 @@
* Parallel tile matrix-matrix multiplication - dynamic scheduling * Parallel tile matrix-matrix multiplication - dynamic scheduling
void morse_pzgemm(cham_trans_t transA, cham_trans_t transB, void chameleon_pzgemm(cham_trans_t transA, cham_trans_t transB,
CHAMELEON_Complex64_t alpha, CHAM_desc_t *A, CHAM_desc_t *B, CHAMELEON_Complex64_t alpha, CHAM_desc_t *A, CHAM_desc_t *B,
CHAMELEON_Complex64_t beta, CHAM_desc_t *C, CHAMELEON_Complex64_t beta, CHAM_desc_t *C,
int m, n, k; int m, n, k;
...@@ -44,10 +44,10 @@ void morse_pzgemm(cham_trans_t transA, cham_trans_t transB, ...@@ -44,10 +44,10 @@ void morse_pzgemm(cham_trans_t transA, cham_trans_t transB,
CHAMELEON_Complex64_t zbeta; CHAMELEON_Complex64_t zbeta;
CHAMELEON_Complex64_t zone = (CHAMELEON_Complex64_t)1.0; CHAMELEON_Complex64_t zone = (CHAMELEON_Complex64_t)1.0;
return; return;
for (m = 0; m < C->mt; m++) { for (m = 0; m < C->mt; m++) {
tempmm = m == C->mt-1 ? C->m-m*C->mb : C->mb; tempmm = m == C->mt-1 ? C->m-m*C->mb : C->mb;
...@@ -141,5 +141,5 @@ void morse_pzgemm(cham_trans_t transA, cham_trans_t transB, ...@@ -141,5 +141,5 @@ void morse_pzgemm(cham_trans_t transA, cham_trans_t transB,
