Commit fd42e344 authored by Mathieu Faverge's avatar Mathieu Faverge
Forgot to move some declarations outside the MAGMA section
parent 31f3a887
......@@ -39,6 +39,7 @@ int CUDA_zgemm( MORSE_enum transa, MORSE_enum transb, int m, int n, int k, cuDo
int CUDA_zhemm( MORSE_enum side, MORSE_enum uplo, int m, int n, cuDoubleComplex *alpha, const cuDoubleComplex *A, int lda, const cuDoubleComplex *B, int ldb, cuDoubleComplex *beta, cuDoubleComplex *C, int ldc, CUBLAS_STREAM_PARAM);
int CUDA_zher2k( MORSE_enum uplo, MORSE_enum trans, int n, int k, cuDoubleComplex *alpha, const cuDoubleComplex *A, int lda, const cuDoubleComplex *B, int ldb, double *beta, cuDoubleComplex *C, int ldc, CUBLAS_STREAM_PARAM);
int CUDA_zherk( MORSE_enum uplo, MORSE_enum trans, int n, int k, double *alpha, const cuDoubleComplex *A, int lda, double *beta, cuDoubleComplex *B, int ldb, CUBLAS_STREAM_PARAM);
int CUDA_zlarfb(MORSE_enum side, MORSE_enum trans, MORSE_enum direct, MORSE_enum storev, int M, int N, int K, const cuDoubleComplex *V, int LDV, const cuDoubleComplex *T, int LDT, cuDoubleComplex *C, int LDC, cuDoubleComplex *WORK, int LDWORK, CUBLAS_STREAM_PARAM );
int CUDA_zparfb(MORSE_enum side, MORSE_enum trans, MORSE_enum direct, MORSE_enum storev, int M1, int N1, int M2, int N2, int K, int L, cuDoubleComplex *A1, int LDA1, cuDoubleComplex *A2, int LDA2, const cuDoubleComplex *V, int LDV, const cuDoubleComplex *T, int LDT, cuDoubleComplex *WORK, int LDWORK, cuDoubleComplex *WORKC, int LDWORKC, CUBLAS_STREAM_PARAM );
int CUDA_zsymm( MORSE_enum side, MORSE_enum uplo, int m, int n, cuDoubleComplex *alpha, const cuDoubleComplex *A, int lda, const cuDoubleComplex *B, int ldb, cuDoubleComplex *beta, cuDoubleComplex *C, int ldc, CUBLAS_STREAM_PARAM);
int CUDA_zsyr2k( MORSE_enum uplo, MORSE_enum trans, int n, int k, cuDoubleComplex *alpha, const cuDoubleComplex *A, int lda, const cuDoubleComplex *B, int ldb, cuDoubleComplex *beta, cuDoubleComplex *C, int ldc, CUBLAS_STREAM_PARAM);
......@@ -47,6 +48,8 @@ int CUDA_ztrmm( MORSE_enum side, MORSE_enum uplo, MORSE_enum transa, MORSE_enum
int CUDA_ztrsm( MORSE_enum side, MORSE_enum uplo, MORSE_enum transa, MORSE_enum diag, int m, int n, cuDoubleComplex *alpha, const cuDoubleComplex *A, int lda, cuDoubleComplex *B, int ldb, CUBLAS_STREAM_PARAM);
int CUDA_ztsmlq( MORSE_enum side, MORSE_enum trans, int M1, int N1, int M2, int N2, int K, int IB, cuDoubleComplex *A1, int LDA1, cuDoubleComplex *A2, int LDA2, const cuDoubleComplex *V, int LDV, const cuDoubleComplex *T, int LDT, cuDoubleComplex *WORK, int LDWORK, cuDoubleComplex *WORKC, int LDWORKC, CUBLAS_STREAM_PARAM);
int CUDA_ztsmqr( MORSE_enum side, MORSE_enum trans, int M1, int N1, int M2, int N2, int K, int IB, cuDoubleComplex *A1, int LDA1, cuDoubleComplex *A2, int LDA2, const cuDoubleComplex *V, int LDV, const cuDoubleComplex *T, int LDT, cuDoubleComplex *WORK, int LDWORK, cuDoubleComplex *WORKC, int LDWORKC, CUBLAS_STREAM_PARAM);
int CUDA_zunmlqt(MORSE_enum side, MORSE_enum trans, int M, int N, int K, int IB, const cuDoubleComplex *A, int LDA, const cuDoubleComplex *T, int LDT, cuDoubleComplex *C, int LDC, cuDoubleComplex *WORK, int LDWORK, CUBLAS_STREAM_PARAM );
int CUDA_zunmqrt(MORSE_enum side, MORSE_enum trans, int M, int N, int K, int IB, const cuDoubleComplex *A, int LDA, const cuDoubleComplex *T, int LDT, cuDoubleComplex *C, int LDC, cuDoubleComplex *WORK, int LDWORK, CUBLAS_STREAM_PARAM );
#if defined(CHAMELEON_USE_MAGMA)
int CUDA_zgelqt( magma_int_t m, magma_int_t n, magma_int_t nb, magmaDoubleComplex *da, magma_int_t ldda, magmaDoubleComplex *v, magma_int_t ldv, magmaDoubleComplex *dt, magma_int_t lddt, magmaDoubleComplex *t, magma_int_t ldt, magmaDoubleComplex *dd, magmaDoubleComplex *d, magma_int_t ldd, magmaDoubleComplex *tau, magmaDoubleComplex *hwork, magmaDoubleComplex *dwork, CUBLAS_STREAM_PARAM);
......@@ -54,7 +57,6 @@ int CUDA_zgeqrt( magma_int_t m, magma_int_t n, magma_int_t nb, magmaDoubleComple
int CUDA_zgessm( char storev, magma_int_t m, magma_int_t n, magma_int_t k, magma_int_t ib, magma_int_t *ipiv, cuDoubleComplex *dL1, magma_int_t lddl1, cuDoubleComplex *dL, magma_int_t lddl, cuDoubleComplex *dA, magma_int_t ldda, magma_int_t *info);
int CUDA_zgetrf_incpiv( char storev, magma_int_t m, magma_int_t n, magma_int_t ib, cuDoubleComplex *hA, magma_int_t ldha, cuDoubleComplex *dA, magma_int_t ldda, cuDoubleComplex *hL, magma_int_t ldhl, cuDoubleComplex *dL, magma_int_t lddl, magma_int_t *ipiv, cuDoubleComplex *dwork, magma_int_t lddwork, magma_int_t *info);
int CUDA_zgetrf_nopiv( magma_int_t m, magma_int_t n, cuDoubleComplex *dA, magma_int_t ldda, magma_int_t *info);
int CUDA_zlauum( char uplo, magma_int_t n, cuDoubleComplex *dA, magma_int_t ldda, magma_int_t *info);
int CUDA_zpotrf( magma_uplo_t uplo, magma_int_t n, magmaDoubleComplex *dA, magma_int_t ldda, magma_int_t *info);
int CUDA_zssssm( magma_storev_t storev, magma_int_t m1, magma_int_t n1, magma_int_t m2, magma_int_t n2, magma_int_t k, magma_int_t ib, magmaDoubleComplex *dA1, magma_int_t ldda1, magmaDoubleComplex *dA2, magma_int_t ldda2, magmaDoubleComplex *dL1, magma_int_t lddl1, magmaDoubleComplex *dL2, magma_int_t lddl2, magma_int_t *IPIV, magma_int_t *info);
......@@ -62,8 +64,6 @@ int CUDA_ztrtri( magma_uplo_t uplo, magma_diag_t diag, magma_int_t n, magmaDoubl
int CUDA_ztslqt( magma_int_t m, magma_int_t n, magma_int_t nb, magmaDoubleComplex *da1, magma_int_t ldda1, magmaDoubleComplex *da2, magma_int_t ldda2, magmaDoubleComplex *a2, magma_int_t lda2, magmaDoubleComplex *dt, magma_int_t lddt, magmaDoubleComplex *t, magma_int_t ldt, magmaDoubleComplex *dd, magmaDoubleComplex *d, magma_int_t ldd, magmaDoubleComplex *tau, magmaDoubleComplex *hwork, magmaDoubleComplex *dwork, CUBLAS_STREAM_PARAM);
int CUDA_ztsqrt( magma_int_t m, magma_int_t n, magma_int_t nb, magmaDoubleComplex *da1, magma_int_t ldda1, magmaDoubleComplex *da2, magma_int_t ldda2, magmaDoubleComplex *a2, magma_int_t lda2, magmaDoubleComplex *dt, magma_int_t lddt, magmaDoubleComplex *t, magma_int_t ldt, magmaDoubleComplex *dd, magmaDoubleComplex *d, magma_int_t ldd, magmaDoubleComplex *tau, magmaDoubleComplex *hwork, magmaDoubleComplex *dwork, CUBLAS_STREAM_PARAM);
int CUDA_ztstrf( char storev, magma_int_t m, magma_int_t n, magma_int_t ib, magma_int_t nb, cuDoubleComplex *hU, magma_int_t ldhu, cuDoubleComplex *dU, magma_int_t lddu, cuDoubleComplex *hA, magma_int_t ldha, cuDoubleComplex *dA, magma_int_t ldda, cuDoubleComplex *hL, magma_int_t ldhl, cuDoubleComplex *dL, magma_int_t lddl, magma_int_t *ipiv, cuDoubleComplex *hwork, magma_int_t ldhwork, cuDoubleComplex *dwork, magma_int_t lddwork, magma_int_t *info);
int CUDA_zunmlqt( magma_side_t side, magma_trans_t trans, magma_int_t M, magma_int_t N, magma_int_t K, magma_int_t IB, const magmaDoubleComplex *A, magma_int_t LDA, const magmaDoubleComplex *T, magma_int_t LDT, magmaDoubleComplex *C, magma_int_t LDC, magmaDoubleComplex *WORK, magma_int_t LDWORK );
int CUDA_zunmqrt( magma_side_t side, magma_trans_t trans, magma_int_t M, magma_int_t N, magma_int_t K, magma_int_t IB, const magmaDoubleComplex *A, magma_int_t LDA, const magmaDoubleComplex *T, magma_int_t LDT, magmaDoubleComplex *C, magma_int_t LDC, magmaDoubleComplex *WORK, magma_int_t LDWORK );
#endif
#ifdef __cplusplus
