Commit f1f59b85 authored by PRUVOST Florent's avatar PRUVOST Florent
Only disable examples and testings if simulation mode because this mode does not support it
parent 075986df
...@@ -1088,14 +1088,14 @@ if(_match_ifort) ...@@ -1088,14 +1088,14 @@ if(_match_ifort)
endif(_match_ifort) endif(_match_ifort)
# Testing executables # Testing executables
if(CHAMELEON_ENABLE_EXAMPLE) if(CHAMELEON_ENABLE_EXAMPLE AND NOT CHAMELEON_SIMULATION)
add_subdirectory(example) add_subdirectory(example)
endif(CHAMELEON_ENABLE_EXAMPLE) endif(CHAMELEON_ENABLE_EXAMPLE AND NOT CHAMELEON_SIMULATION)
if(CHAMELEON_ENABLE_TESTING) if(CHAMELEON_ENABLE_TESTING AND NOT CHAMELEON_SIMULATION)
add_subdirectory(testing) add_subdirectory(testing)
endif(CHAMELEON_ENABLE_TESTING) endif(CHAMELEON_ENABLE_TESTING AND NOT CHAMELEON_SIMULATION)
# Timing executables # Timing executables
if(CHAMELEON_ENABLE_TIMING) if(CHAMELEON_ENABLE_TIMING)
