Commit f0ecf1f0 authored by THIBAULT Samuel's avatar THIBAULT Samuel
Allow MPI in simulation mode, just use smpicc instead of mpicc
parent e9ad21b0
...@@ -465,7 +465,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/") ...@@ -465,7 +465,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
# -DMPI_C_COMPILER=path/to/mpicc -DMPI_Fortran_COMPILER=path/to/mpif90 # -DMPI_C_COMPILER=path/to/mpicc -DMPI_Fortran_COMPILER=path/to/mpif90
# at cmake configure # at cmake configure
if(NOT MPI_C_COMPILER) if(NOT MPI_C_COMPILER)
set(MPI_C_COMPILER mpicc) if(NOT CHAMELEON_SIMULATION)
else(NOT CHAMELEON_SIMULATION)
set(MPI_C_COMPILER smpicc)
endif()
endif() endif()
find_package(MPI REQUIRED) find_package(MPI REQUIRED)
...@@ -509,12 +513,6 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/") ...@@ -509,12 +513,6 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
"Because we are compiling the simulation mode (CHAMELEON_SIMULATION=ON)," "Because we are compiling the simulation mode (CHAMELEON_SIMULATION=ON),"
"we do not need to link with MAGMA.${ColourReset}") "we do not need to link with MAGMA.${ColourReset}")
endif () endif ()
if (CHAMELEON_USE_MPI)
set(CHAMELEON_USE_MPI OFF)
message("${BoldBlue}CHAMELEON_USE_MPI is set to ON but we turn it OFF."
"we do not need to link with MPI.${ColourReset}")
endif ()
if (CHAMELEON_ENABLE_TESTING) if (CHAMELEON_ENABLE_TESTING)
set(CHAMELEON_ENABLE_TESTING OFF) set(CHAMELEON_ENABLE_TESTING OFF)
message("${BoldBlue}CHAMELEON_ENABLE_TESTING is set to ON but we turn it OFF." message("${BoldBlue}CHAMELEON_ENABLE_TESTING is set to ON but we turn it OFF."
Supports Markdown
