Commit ed7e0acb authored by THIBAULT Samuel's avatar THIBAULT Samuel
Also use folded allocation for data received by MPI.
parent 58515121
......@@ -641,6 +641,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
if ( STARPU_DATA_WONT_USE_FOUND )
add_definitions(-DCHAMELEON_USE_STARPU_DATA_WONT_USE)
endif()
check_function_exists(starpu_malloc_on_node_set_default_flags STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS)
if ( STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS )
add_definitions(-DCHAMELEON_USE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS)
endif()
if(CHAMELEON_ENABLE_TRACING)
# check if fxt profiling is accessible in starpu and activate it in chameleon
unset(STARPU_FXT_START_PROFILING_FOUND CACHE)
......@@ -4,7 +4,7 @@
* of Tennessee Research Foundation.
* All rights reserved.
* @copyright (c) 2012-2014 Inria. All rights reserved.
* @copyright (c) 2012-2015 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
* @copyright (c) 2012-2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
......@@ -102,6 +102,10 @@ int RUNTIME_init_scheduler( MORSE_context_t *morse, int ncpus, int ncudas, int n
morse->nthreads_per_worker = nthreads_per_worker;
#ifdef CHAMELEON_USE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS
starpu_malloc_on_node_set_default_flags(STARPU_MAIN_RAM, STARPU_MALLOC_PINNED | STARPU_MALLOC_COUNT | STARPU_MALLOC_SIMULATION_FOLDED);
#endif
#if defined(CHAMELEON_USE_MPI)
int flag = 0;
