Commit e65976ac authored by Mathieu Faverge's avatar Mathieu Faverge
Remove references to Complex in map functions
parent 091e3311
...@@ -49,7 +49,7 @@ void INSERT_TASK_map( const RUNTIME_option_t *options, ...@@ -49,7 +49,7 @@ void INSERT_TASK_map( const RUNTIME_option_t *options,
sizeof(cham_uplo_t), &uplo, VALUE, sizeof(cham_uplo_t), &uplo, VALUE,
sizeof(int), &Am, VALUE, sizeof(int), &Am, VALUE,
sizeof(int), &An, VALUE, sizeof(int), &An, VALUE,
PASSED_BY_REF, RTBLKADDR(A, CHAMELEON_Complex64_t, Am, An), chameleon_parsec_get_arena_index( A ) | INOUT, PASSED_BY_REF, RTBLKADDR(A, void, Am, An), chameleon_parsec_get_arena_index( A ) | INOUT,
sizeof(cham_unary_operator_t), &operator, VALUE, sizeof(cham_unary_operator_t), &operator, VALUE,
sizeof(void*), &op_args, VALUE, sizeof(void*), &op_args, VALUE,
PARSEC_DTD_ARG_END ); PARSEC_DTD_ARG_END );
...@@ -43,7 +43,7 @@ void INSERT_TASK_map( const RUNTIME_option_t *options, ...@@ -43,7 +43,7 @@ void INSERT_TASK_map( const RUNTIME_option_t *options,
sizeof(CHAMELEON_Complex64_t), RTBLKADDR(A, CHAMELEON_Complex64_t, Am, An), INOUT, sizeof(char), RTBLKADDR(A, void, Am, An), INOUT,
0); 0);
