Commit d6624e2f authored by PRUVOST Florent's avatar PRUVOST Florent
find runtimes dependencies not required in order to make verbose mode usefull
parent cb656faf
...@@ -316,7 +316,7 @@ if(NOT CHAMELEON_SIMULATION) ...@@ -316,7 +316,7 @@ if(NOT CHAMELEON_SIMULATION)
# CHAMELEON depends on LAPACKE # CHAMELEON depends on LAPACKE
find_package(LAPACKEXT) find_package(LAPACKEXT REQUIRED)
if(LAPACK_FOUND AND LAPACK_LIBRARY_DIRS) if(LAPACK_FOUND AND LAPACK_LIBRARY_DIRS)
# the RPATH to be used when installing # the RPATH to be used when installing
list(APPEND CMAKE_INSTALL_RPATH "${LAPACK_LIBRARY_DIRS}") list(APPEND CMAKE_INSTALL_RPATH "${LAPACK_LIBRARY_DIRS}")
...@@ -527,7 +527,7 @@ if( CHAMELEON_SCHED_STARPU ) ...@@ -527,7 +527,7 @@ if( CHAMELEON_SCHED_STARPU )
list(APPEND STARPU_COMPONENT_LIST "FXT") list(APPEND STARPU_COMPONENT_LIST "FXT")
endif() endif()
find_package(STARPU ${CHAMELEON_STARPU_VERSION} REQUIRED find_package(STARPU ${CHAMELEON_STARPU_VERSION}
COMPONENTS ${STARPU_COMPONENT_LIST}) COMPONENTS ${STARPU_COMPONENT_LIST})
# Add definition and include_dir if found # Add definition and include_dir if found
...@@ -639,7 +639,7 @@ endif( CHAMELEON_SCHED_STARPU ) ...@@ -639,7 +639,7 @@ endif( CHAMELEON_SCHED_STARPU )
# try to find quark runtime # try to find quark runtime
if( CHAMELEON_SCHED_QUARK ) if( CHAMELEON_SCHED_QUARK )
find_package(QUARK REQUIRED COMPONENTS HWLOC) find_package(QUARK COMPONENTS HWLOC)
if(QUARK_FOUND) if(QUARK_FOUND)
