Commit ca3b5e73 authored by PRUVOST Florent's avatar PRUVOST Florent
remove duplicate functions declaration in cudablas_eztrace_module
parent 28718b7d
......@@ -455,58 +455,6 @@ int CUDA_dssssm(
double *dL1, void* lddl1,
double *dL2, void* lddl2,
void* *IPIV, void* info);
int CUDA_dsymm_V2(
void* side, void* uplo,
int m, int n,
double *alpha,
const double *A, int lda,
const double *B, int ldb,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dsymm(
int m, int n,
double *alpha,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dsyr2k_V2(
void* uplo, void* trans,
int n, int k,
double *alpha,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dsyr2k(
int n, int k,
double *alpha,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dsyrk_V2(
int n, int k,
double *alpha,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dsyrk(
int n, int k,
double *alpha,
double *beta,
double *C, int ldc,
void* stream);
int CUDA_dtrmm_V2(
void* transa, void* diag,
......@@ -762,58 +710,6 @@ int CUDA_sssssm(
float *dL1, void* lddl1,
float *dL2, void* lddl2,
int CUDA_ssymm_V2(
int m, int n,
float *alpha,
const float *A, int lda,
const float *B, int ldb,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_ssymm(
int m, int n,
float *alpha,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_ssyr2k_V2(
int n, int k,
float *alpha,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_ssyr2k(
int n, int k,
float *alpha,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_ssyrk_V2(
int n, int k,
float *alpha,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_ssyrk(
int n, int k,
float *alpha,
float *beta,
float *C, int ldc,
void* stream);
int CUDA_strmm_V2(
