Commit b4003e77 authored by Samuel Thibault's avatar Samuel Thibault
Add tile coordinates within matrix
parent 665853f4
......@@ -4,7 +4,7 @@
# of Tennessee Research Foundation.
# All rights reserved.
# @copyright (c) 2012-2016 Inria. All rights reserved.
# @copyright (c) 2012-2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
# @copyright (c) 2012-2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
......@@ -711,6 +711,11 @@ if( CHAMELEON_SCHED_STARPU )
set(HAVE_STARPU_DATA_WONT_USE 1)
message("-- ${Blue}Add definition HAVE_STARPU_DATA_WONT_USE${ColourReset}")
endif()
check_function_exists(starpu_data_set_coordinates STARPU_DATA_SET_COORDINATES_FOUND)
if ( STARPU_DATA_SET_COORDINATES_FOUND )
set(HAVE_STARPU_DATA_SET_COORDINATES 1)
message("-- ${Blue}Add definition HAVE_STARPU_DATA_SET_COORDINATES${ColourReset}")
endif()
check_function_exists(starpu_malloc_on_node_set_default_flags STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS)
if ( STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS )
set(HAVE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS 1)
* of Tennessee Research Foundation.
* All rights reserved.
* @copyright (c) 2012-2017 Inria. All rights reserved.
* @copyright (c) 2012-2015 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
* @copyright (c) 2012-2015, 2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
......@@ -35,6 +35,7 @@
#cmakedefine HAVE_STARPU_FXT_PROFILING
#cmakedefine HAVE_STARPU_IDLE_PREFETCH
#cmakedefine HAVE_STARPU_DATA_WONT_USE
#cmakedefine HAVE_STARPU_DATA_SET_COORDINATES
#cmakedefine HAVE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS
#cmakedefine HAVE_STARPU_MPI_DATA_REGISTER
#cmakedefine HAVE_STARPU_MPI_COMM_RANK
* @copyright (c) 2012-2016 Inria. All rights reserved.
* @copyright (c) 2012-2014, 2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
* @copyright (c) 2012-2014, 2016-2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
......@@ -330,6 +330,10 @@ void *RUNTIME_desc_getaddr( const MORSE_desc_t *desc, int m, int n )
BLKLDD(desc, im), tempmm, tempnn, eltsze);
#ifdef HAVE_STARPU_DATA_SET_COORDINATES
starpu_data_set_coordinates(*ptrtile, 2, m, n);
#endif
#if defined(CHAMELEON_USE_MPI)
int64_t block_ind = desc->lmt * jn + im;
